I am new here and need help with adding new integration my HASSIO
So i just installed hass.io on my pi3. and after installing configurator, i was trying to add my venstar thermostat from ‘Add new repository by URL’, but it does not work. i tried to different URL’s and didn’t work.
Can anyone help me?
This is the component:
here is the log for both tries (i tried some other stuff, but didnt work as well…)
19-08-21 15:29:27 INFO (MainThread) [hassio.store.git] Clone add-on https://github.com/home-assistant/home-assistant/blob/08d797edba563efec5983a7b506229066d6a1e7a/homeassistant/components/venstar/manifest.json repository
19-08-21 15:29:28 ERROR (MainThread) [hassio.store.git] Can't clone https://github.com/home-assistant/home-assistant/blob/08d797edba563efec5983a7b506229066d6a1e7a/homeassistant/components/venstar/manifest.json repository: Cmd('git') failed due to: exit code(128)
  cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/home-assistant/home-assistant/blob/08d797edba563efec5983a7b506229066d6a1e7a/homeassistant/components/venstar/manifest.json /data/addons/git/d690cf40
  stderr: 'Cloning into '/data/addons/git/d690cf40'...
fatal: repository 'https://github.com/home-assistant/home-assistant/blob/08d797edba563efec5983a7b506229066d6a1e7a/homeassistant/components/venstar/manifest.json/' not found
19-08-21 15:29:28 ERROR (MainThread) [hassio.store] Can't load from repository https://github.com/home-assistant/home-assistant/blob/08d797edba563efec5983a7b506229066d6a1e7a/homeassistant/components/venstar/manifest.json
19-08-21 15:29:28 INFO (MainThread) [hassio.store] Load add-ons from store: 60 all - 0 new - 0 remove
19-08-21 15:31:31 INFO (MainThread) [hassio.store.git] Clone add-on https://github.com/home-assistant/home-assistant/tree/dev/homeassistant/components/venstar repository
19-08-21 15:31:32 ERROR (MainThread) [hassio.store.git] Can't clone https://github.com/home-assistant/home-assistant/tree/dev/homeassistant/components/venstar repository: Cmd('git') failed due to: exit code(128)
  cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/home-assistant/home-assistant/tree/dev/homeassistant/components/venstar /data/addons/git/82b65fd3
  stderr: 'Cloning into '/data/addons/git/82b65fd3'...
fatal: repository 'https://github.com/home-assistant/home-assistant/tree/dev/homeassistant/components/venstar/' not found
19-08-21 15:31:32 ERROR (MainThread) [hassio.store] Can't load from repository https://github.com/home-assistant/home-assistant/tree/dev/homeassistant/components/venstar
19-08-21 15:31:32 INFO (MainThread) [hassio.store] Load add-ons from store: 60 all - 0 new - 0 remove
Thank you so much.
All integrations listed in the Home Assistant documentation are already included. You don’t have to install anything.
Simply follow the documentation for that component to set it up.
is not for adding components/integrations. It is for add-ons which are not integrations/components.
