I want to be able to send TTS to my Samsung S21+ which has HA and the Companion app installed. Ideally I want to use Amazon Polly and use a Jarvis voice. However, at this point I have been unable to get any tts to play on my phone. I am trying to just use Develop tools > Actions and insert some yaml code and then click on perform action. Here is an example of the code I would really like to be able to use:
action: notify.alexa_media
message: >
<voice name="{{ states('input_select.jarvis_voice') }}">
<amazon:auto-breaths>
<prosody rate="fast">
Pardon me, Lightning has been detected. If you'd rather not be a crispy critter, you should probably take shelter in the basement.
</prosody>
</amazon:auto-breaths>
</voice>
target: notify.mobile_app_mike_phone
type: tts
My goal is to be able to have HA play a morning briefing to me each day that contains the weather, calendar events, etc. Some days I might be in the living room for example, and would use the Alexa device in the room. But other days I might be in a room that has no Alexa, or maybe outside or driving in my car. So in those instances I want the briefing to be played on my phone.
I have tried changing things in HA, in the Companiuon app and onthe phone, But as of yet, I have been unable to get any tts to play on the phone.
I would be very appreciative of anyone that can help me solve this.
OK, I finally for the first time got tts on my phone using the following yaml in Developer tools > Actions:
action: notify.mobile_app_mike_phone
message: TTS
ttl: 0
priority: high
media_stream: alarm_stream
tts_text: The house is on fire and the cat's stuck in the dryer!
The issue is that is it playing at about 20x speed, so it is impossible to understand. How can I change the speed, and maybe the voice?
Thanks so much for your continued help and support!!!
I am not sure where to find that. It seems like the Samsung Galaxy S21+ 5G has moved the tts around. I finally found it, but i am not aware of any settings. I will try to do some more digging.
Success. It was moved in an update a while back, but I managed to find it. Problem solved. Just out of curiosity, can I use other voices and amazon polly, or is it whatever the default is and not able to be changed?
