I get the above error when I try to access the Zigbee2mqtt tab, I get the same error message when I try to access the terminal tab. When I try to access the host logs, I get Failed to get host logs, 502: Bad Gateway. When I try to access the supervisor logs I get Failed to get supervisor logs, 502: Bad Gateway. How can I go back to a working version and see what is causing my issue. Thank you in advance
Hello, did you have a reply or fix the problem ?
I have the same issue here.
I am having the exact same issue.
502: Bad Gateway on addons (NodeRed, zigbe2mqtt, file editor) when trying to load them, cant access addons via settings, and supervisor logs is also giving 502 error when trying to load.
As soon as I start getting 502 errors, the system works perfectly fine. I just can not do anything with it.
It is not possible to reload core via UI in developoer tools, and i have to do a shutdown via SSH.
When HA has started again everything works perfectly fine for a moment, however it all of a sudden starts giving 502 errors again.
So it is just a temp fix (allows me to update and change some settings).
I am suspecting a corrupt MariaDB. After deleting it and reinstalling the 502 errors went away.
Has anyone else had any success? I’m still getting bad gateway on all addons. I can restart my server and they will work for a little bit then revert back. I even tried to do a backup restore to a previous version, but I’m still having the same issue. I just looked and didn’t have mariaDB installed.
Did you ever find a solution? I’m still having the issue and it’s driving me nuts
On my side, it was a problem of writing and reading data on the SD card. Fixed by migrating HA to a VM.
