I broke my scenes.yaml with input_number - what did I do wrong?
Hello all,
As given in the documentation on input_number, I’m trying to do this in my scenes.yaml:
- id: '1673730606299'
  name: Hall Lights 0 off
  entities:
    input_number.hallway_scene: 0
However, I get the error:
Invalid config for [scene]: State for input_number.hallway_scene should be a string for dictionary value @ data[‘states’][0][‘entities’]. Got None. (See /config/configuration.yaml, line 10).
The integrations doc
says:
# Example configuration.yaml entry
scene:
  - name: Example Scene
    entities:
      input_number.example_number: 13
Question 1: What’s the issue?
Question 2: I have a related question. The scene is no longer available for setting (understandably). When I try to call that scene, I get this:
Unable to find referenced entities scene.hall_lights_0_off or it is/they are currently not available
Where does the id come from? Is it just the name in lower case with _? If that’s true, then what does the id: '1673730606299' do?
Many thanks!
It seems that “…” is needed around the numbers:
  entities:
    input_number.hallway_scene: "0"
It’s not clear to me why that is… but it does work.
