Okei, so after changing the frontend port to 8080 in the Z2M config file I got the web interface to show. That’s a bit embarrassing, but thank you for notifying it @dproffer. It got me one step further.
However, nothing seems to connect when I put my devices into pair mode and press the “Permit Join (All)” button. I have gotten to this point with another configuration earlier. I don’t have those configurations unfortunately. This almost leads me to believe that there is something wrong either with the MQTT broker or the hardware (i.e. the Conbee II itself)…
I have tried several times, as I have heard one might have to do, but still no connections. I am trying to pair an IKEA TRADFRI remote control. This is the log output from the Z2M container:
Zigbee2MQTT:info 2022-10-13 19:39:36: Connecting to MQTT server at mqtt://192.168.50.69:1883
Zigbee2MQTT:info 2022-10-13 19:39:36: Connected to MQTT server
Zigbee2MQTT:info 2022-10-13 19:39:36: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:info 2022-10-13 19:39:36: Started frontend on port 0.0.0.0:8080
Zigbee2MQTT:info 2022-10-13 19:39:36: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"03ba647","coordinator":{"meta":{"maintrel":0,"majorrel":38,"minorrel":114,"product":0,"revision":"0x26720700","transportrev":0},"type":"ConBee2/RaspBee2"},"log_level":"info","network":{"channel":15,"extendedPanID":"0xdddddddddddddddd","panID":6754},"permit_join":false,"version":"1.28.0"}'
Zigbee2MQTT:info 2022-10-13 20:10:31: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2022-10-13 20:10:31: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"bbax5-1"}'
Zigbee2MQTT:info 2022-10-13 20:15:28: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2022-10-13 20:15:29: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"stekl-1"}'
Zigbee2MQTT:info 2022-10-13 20:22:36: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2022-10-13 20:22:37: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"stekl-2"}'
Zigbee2MQTT:info 2022-10-13 20:26:57: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2022-10-13 20:26:58: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"stekl-3"}'
The Mosquitto MQTT container has the following log output in Portainer
No log line matching the '' filter
But when I open a terminal inside it and run the command cat mosquitto/log/mosquitto.log
I get the following output:
1665594587: mosquitto version 2.0.15 starting
1665594587: Config loaded from /mosquitto/config/mosquitto.conf.
1665594587: Opening ipv4 listen socket on port 1883.
1665594587: Opening ipv6 listen socket on port 1883.
1665594587: mosquitto version 2.0.15 running
1665594781: mosquitto version 2.0.15 terminating
1665594781: Saving in-memory database to /mosquitto/data//mosquitto.db.
1665594782: mosquitto version 2.0.15 starting
1665594782: Config loaded from /mosquitto/config/mosquitto.conf.
1665594782: Opening ipv4 listen socket on port 1883.
1665594782: Opening ipv6 listen socket on port 1883.
1665594782: mosquitto version 2.0.15 running
1665594856: New connection from 192.168.50.69:36987 on port 1883.
1665594856: New client connected from 192.168.50.69:36987 as 1EkPK19gAwxCtjYDVmF7cx (p1, c1, k60, u'hass').
1665594856: Client 1EkPK19gAwxCtjYDVmF7cx disconnected.
1665594856: New connection from 192.168.50.69:47061 on port 1883.
1665594856: New client connected from 192.168.50.69:47061 as 2CxFc1O28jxxYLxxKveu69 (p2, c1, k60, u'hass').
1665595278: New connection from 172.18.0.1:47740 on port 1883.
1665595278: New client connected from 172.18.0.1:47740 as mqttjs_25e7ab33 (p2, c1, k60, u'hass').
1665595336: Client 2CxFc1O28jxxYLxxKveu69 closed its connection.
1665595349: New connection from 192.168.50.69:57441 on port 1883.
1665595349: New client connected from 192.168.50.69:57441 as 4pWozNmsCGV54ihVYb4Wdb (p2, c1, k60, u'hass').
1665595465: Client mqttjs_25e7ab33 disconnected.
1665595512: New connection from 172.18.0.1:57042 on port 1883.
1665595512: New client connected from 172.18.0.1:57042 as mqttjs_eb7318e0 (p2, c1, k60, u'hass').
1665595526: Client mqttjs_eb7318e0 disconnected.
1665595532: New connection from 172.18.0.1:54012 on port 1883.
1665595532: New client connected from 172.18.0.1:54012 as mqttjs_919f3267 (p2, c1, k60, u'hass').
1665595567: New connection from 192.168.50.123:53975 on port 1883.
1665595567: New connection from 192.168.50.123:53976 on port 1883.
1665595567: Client <unknown> disconnected due to malformed packet.
1665595568: Client <unknown> disconnected due to malformed packet.
1665595568: New connection from 192.168.50.123:53977 on port 1883.
1665595573: New connection from 192.168.50.123:53978 on port 1883.
1665595573: New connection from 192.168.50.123:53979 on port 1883.
1665595573: Client <unknown> disconnected due to malformed packet.
1665595634: Client <unknown> closed its connection.
1665595863: Client mqttjs_919f3267 disconnected.
1665596494: mosquitto version 2.0.15 terminating
1665596494: Saving in-memory database to /mosquitto/data//mosquitto.db.
1665596495: mosquitto version 2.0.15 starting
1665596495: Config loaded from /mosquitto/config/mosquitto.conf.
1665596495: Opening ipv4 listen socket on port 1883.
1665596495: Opening ipv6 listen socket on port 1883.
1665596495: mosquitto version 2.0.15 running
1665596497: New connection from 192.168.50.69:60757 on port 1883.
1665596497: New client connected from 192.168.50.69:60757 as 4pWozNmsCGV54ihVYb4Wdb (p2, c1, k60, u'hass').
1665596978: New connection from 172.18.0.1:40622 on port 1883.
1665596978: New client connected from 172.18.0.1:40622 as mqttjs_81968336 (p2, c1, k60, u'hass').
1665597274: mosquitto version 2.0.15 terminating
1665597274: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665598509: mosquitto version 2.0.15 starting
1665598509: Config loaded from /mosquitto/config/mosquitto.conf.
1665598509: Opening ipv4 listen socket on port 1883.
1665598509: Opening ipv6 listen socket on port 1883.
1665598509: mosquitto version 2.0.15 running
1665598516: New connection from 192.168.50.69:38647 on port 1883.
1665598516: New client connected from 192.168.50.69:38647 as 7GUpbpDXAGHUXFk2bL6OaZ (p2, c1, k60, u'hass').
1665598588: New connection from 172.18.0.1:35698 on port 1883.
1665598588: New client connected from 172.18.0.1:35698 as mqttjs_65199989 (p2, c1, k60, u'hass').
1665598627: Client mqttjs_65199989 disconnected.
1665598633: New connection from 172.18.0.1:38592 on port 1883.
1665598633: New client connected from 172.18.0.1:38592 as mqttjs_15fdc22d (p2, c1, k60, u'hass').
1665600310: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665602111: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665603912: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665605713: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665607514: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665609315: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665611116: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665612917: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665614718: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665616519: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665618320: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665620121: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665621922: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665623723: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665625524: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665627325: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665629126: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665630927: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665632728: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665634529: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665636330: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665638131: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665639932: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665641733: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665643534: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665645335: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665647136: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665648937: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665650738: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665652539: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665654340: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665656141: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665657942: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665659743: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665661544: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665663345: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665665146: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665666947: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665668748: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665670549: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665672350: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665674151: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665675952: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665677753: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665679554: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665681355: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665682465: Client mqttjs_15fdc22d disconnected.
1665682629: mosquitto version 2.0.15 terminating
1665682629: Saving in-memory database to /mosquitto/data/mosquitto.db.
1665682630: mosquitto version 2.0.15 starting
1665682630: Config loaded from /mosquitto/config/mosquitto.conf.
1665682630: Opening ipv4 listen socket on port 1883.
1665682630: Opening ipv6 listen socket on port 1883.
1665682630: mosquitto version 2.0.15 running
1665682631: New connection from 192.168.50.69:37733 on port 1883.
1665682631: New client connected from 192.168.50.69:37733 as 7GUpbpDXAGHUXFk2bL6OaZ (p2, c1, k60, u'hass').
1665682776: New connection from 172.18.0.1:55814 on port 1883.
1665682776: New client connected from 172.18.0.1:55814 as mqttjs_f54116a7 (p2, c1, k60, u'hass').
1665684431: Saving in-memory database to /mosquitto/data/mosquitto.db.
Not sure what all those new connections are, and why this log does not show up in the Portainer log.
Also. Not sure what to do from here.
