I cannot access homeassistant.local
Hello everyone. I installed Let’s Encrypt plugin for SSL setup and restarted after configuring. But now I can’t reach both homeassistant.local and my local address 192.168.1.132:8123. I think the “samba share” plugin is not working anymore because I can’t access it from FTP either. I installed it with Cloudflare API via my domain address. After that it became unreachable. How can I solve it? I deleted Let’s Encrypt codes in configration.yaml but of course it doesn’t work because the plugin works automatically at boot and it doesn’t fix it.
For those wondering about the solution: My raspberry pi 5 could not see the sd card. It was fixed by unplugging and plugging the device in a few times.
After installation of let’s encrypt, http:// does not work anymore, you need to use https://
I also tried typing https://homeassistant.local:8123/ and https://192.168.1.132:8123/ but the interface still does not open. I unplugged and plugged it back in to restart my Raspberry Pi 5. This time the devices are not communicating with each other either. I guess the home assistant is no longer able to start :frowning:
