I can't seem to add all of my Grid consumption tariffs to the energy dashboard
I have set up an energy consumption monitor with zigbee2mqtt and that seems to mostly be working. I set up a Utility Meter helper and created 4 tariffs under it.
  • Peak beginning at 6am
  • Shoulder beginning at 10am
  • Peak (again) beginning at 3pm
  • Offpeak beginning at 1am
I have set up an automation to assign change which tariff is active at those times and that is working. - I can place all four of them on a card and they will count up at their relative times.
Meters working
If, however, I go to edit the Energy dashboard and click ‘Add Consumption’ only two of the tariffs are available for selection.
grid consumption
I don’t understand why, as they were all set up the same way and all appear the same.
OK, I have remade the Utility Meter helper with a new name and now it is functioning as expected as far as I can tell. Hopefully it stays that way,
