I don't get an option for iBeacon
I picked up a bluecharm tracker and am following the instructions in the docs.
I don’t get far. iBeacon does not appear as an installed application or available integration. It is just not there… similar to this post
iBeacon Tracker Integration Missing - Configuration - Home Assistant Community
The thing is that I recall seeing popups a while back about trackers being detected… so is the integration part of the core install now or something? It was a while ago
link to the docs
If I do a ADD TO HOME ASSISTANT, I get a not found for the integration
Thanks for any tips
EDIT: So I turned on the beacon and I get prompted to add an iBeacon… do the instructions need to be updated? If so, maybe I can submit an issue somewhere
