I fail to read data from influxdb on nas
I run HA core 2026.4.2, supervisor 2026.04.0 and OS 17.2 on a Home Assistant blue.
I try to setup BESS manager which wants influxdb support.
I don’t think my influxdb setup is working even if I don’t see any errors in the logs. BESS manager gives me warnings that influxdb data is missing.
Influxdb setup
I have setup influxdb with chronograf and kapacitor on my synology NAS via docker with standard ports.
In chronograf I have create
  • A database homeassistant.
  • One user homeassistant with read/write access to database homeassistant.
  • One user bess with read access to database homeassistant
Home assistant config of influxdb
In configuration.yaml I have added the following rows:
influxdb:
  max_retries: 3
  include:
    entities:
      <list of 15 sensors>
I have added the influxdb integration and configured it with
  • host: http://:8086
  • user: homeassistant
  • password:
HA answers ok when pressing ok.
After a couple of minutes I can see that data is populated in influxdb via chronograf. DB is not empty even if I don’t really know how to explore data via chronograf.
The BESS manager installation page propose to run the following curl command to see if I have data:
curl -G "http://<nas ip>:8086/query" \
  --data-urlencode "db=homeassistant" \
  --data-urlencode "q=SELECT last(value) FROM /sensor.*/ LIMIT 5" \
  -u "bess:<password>"
I get this respons:
{"results":[{"statement_id":0}]}
I should get a lot of data here I thought.
Is there something obvious that I have missed in my setup above?
I have read about influxdb problem when running on OS 17.x, e.g. in InfluxDB stopped working after updating to HAS 2026.1.2 - #10 by i.nijman.
Edit: I did restart home assistant after all configuration to secure that all configs were applied.
Problem solved.
InfluxDB standard configuration has disabled flux query language. After enabling flux it works as it should.
