I get this message after updating nginx
I’m getting this message after updating nginx to 2.2:
nginx: [warn] the “ssl” directive is deprecated, use the “listen . . . ssl” directive instead in /etc/nginx.conf:45
any idea on how I can fix this ?
Thank you
same here any ideas?
Fix your nginx config?
this is my nginx config:
“domain”: “mydnsdomain”,
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”,
“hsts”: “max-age=31536000; includeSubDomains”,
“customize”: {
“active”: false,
“default”: “nginx_proxy_default*.conf”,
“servers”: “nginx_proxy/*.conf”
what is there to fix ? any idea ?
That’s not a nginx config, so I assume you are using the add-on. Your config file should be in the nginx_proxy directory according to the information you’ve provided…look at the actual nginx config and modify it.
this is what i found in /etc/nginx/nginx.conf
# /etc/nginx/nginx.conf
user nginx;
# Set number of worker processes automatically based on number of CPU cores.
worker_processes auto;
# Enables the use of JIT for regular expressions to speed-up their processing.
pcre_jit on;
# Configures default error logger.
error_log /var/log/nginx/error.log warn;
# Includes files with directives to load dynamic modules.
include /etc/nginx/modules/*.conf;
events {
	# The maximum number of simultaneous connections that can be opened by
	# a worker process.
	worker_connections 1024;
http {
	# Includes mapping of file name extensions to MIME types of responses
	# and defines the default type.
	include /etc/nginx/mime.types;
	default_type application/octet-stream;
	# Name servers used to resolve names of upstream servers into addresses.
	# It's also needed when using tcpsocket and udpsocket in Lua modules.
	#resolver 208.67.222.222 208.67.220.220;
	# Don't tell nginx version to clients.
	server_tokens off;
	# Specifies the maximum accepted body size of a client request, as
	# indicated by the request header Content-Length. If the stated content
	# length is greater than this size, then the client receives the HTTP
	# error code 413. Set to 0 to disable.
	client_max_body_size 1m;
	# Timeout for keep-alive connections. Server will close connections after
	# this time.
	keepalive_timeout 65;
	# Sendfile copies data between one FD and other from within the kernel,
	# which is more efficient than read() + write().
	sendfile on;
	# Don't buffer data-sends (disable Nagle algorithm).
	# Good for sending frequent small bursts of data in real time.
	tcp_nodelay on;
	# Causes nginx to attempt to send its HTTP response head in one packet,
	# instead of using partial frames.
	#tcp_nopush on;
	# Path of the file with Diffie-Hellman parameters for EDH ciphers.
	#ssl_dhparam /etc/ssl/nginx/dh2048.pem;
	# Specifies that our cipher suits should be preferred over client ciphers.
	ssl_prefer_server_ciphers on;
	# Enables a shared SSL cache with size that can hold around 8000 sessions.
	ssl_session_cache shared:SSL:2m;
	# Enable gzipping of responses.
	#gzip on;
	# Set the Vary HTTP header as defined in the RFC 2616.
	gzip_vary on;
	# Enable checking the existence of precompressed files.
	#gzip_static on;
	# Specifies the main log format.
	log_format main '$remote_addr - $remote_user [$time_local] "$request" '
			'$status $body_bytes_sent "$http_referer" '
			'"$http_user_agent" "$http_x_forwarded_for"';
	# Sets the path, format, and configuration for a buffered log write.
	access_log /var/log/nginx/access.log main;
	# Includes virtual hosts configs.
	include /etc/nginx/conf.d/*.conf;
any idea what should it be changed in this file ?
Since it’s not formatted correctly, I can’t read it. Please format code using the code blocks.
better now ?
/etc/nginx??
How did you get there?
What you need is the conf file that it is looking at.
and where that would be ? can you tell from looking at the above file ?
Your add-on config states the location?
Honestly this sounds like something you need to take up with the add-on developer
This is something in one of your vhost
in the server section of one your virtual host
you have to write something like this.
server {
listen 443 ssl http2;
etc
etc
