I’m pretty new to HA (HAOS installed via VM on Synology) and have a TubesZB PoE Z-Wave controller along with the Z-Wave JS UI to make it all work. Everything is on the latest stable firmware version available. I’ve got 50+ Z-Wave devices running for several weeks now so… so far, so good.
I’m still a little fuzzy on how everything works though and have a few questions that I’m hoping someone can help me out with. Feel free to chime in on any of these that you feel you have info on. Thanks in advance for taking the time to read and help.
► Item #1: When I first set everything up, I was getting a repair message on my settings screen telling m that an Add-on Failed to start at boot. When I click for details it said that the port incorrect or is used in multiple add-ons. I clicked “start” and then things worked fine for a bit but it would return.
Then, maybe a month or so ago, this error went away and stayed away. It wasn’t until a recent update that it start appearing again. Now when I click on “start” though it says it was successful bit doesn’t seem to correct the issue and the repair error returns pretty soon.
I’m not sure really what it means or how to go about fixing the issue although I’m sure it’s likely on that I caused during setup given how little I know about these things from a technical standpoint. Everything seems to be working properly still though so I’m not sure really what this is even impacting.
► Item #2: None of my connected Z-Wave devices show as connected via Z-Wave LR w/the purple icon even though I have several of the 800LR devices connected. They all appear to be just connected via the legacy blue Z-Wave protocol just like my older Z-Wave devices.
Is there something I should do during the initial inclusion so that these all use the newest and most secure protocol available? I think that most of these were added from the Z-Wave add-on as opposed to the JS UI option but I recently added a device and saw where it gave me more options during inclusion to force various connectivity inclusion methods. I didn’t opt for this however and new 800LR devices still weren’t being included as 800LR seemingly. Which brings me to my next question…
► Item #3: Should I be using the Z-Wave add on or the JS UI add-on for including new devices? I assume it doesn’t matter unless I need to manually specify the Z-Wave type or security protocol but I assume that it’s the same otherwise. I also couldn’t find a way to exclude devices from the Z-Wave add-on so I was using the JS UI interface for exclusion.
► Item #4: How do I modify the routes/hops that devices take from within the JS UI Network Graph screen? I think I saw someone had said that you could easily do that but I don’t see the option. I have some devices that are taking some VERY interesting and seemingly needless routes to get to my TubesZB PoE Z-Wave controller. One such example is an older battery powered sensor that was on the front porch just outside of my office. From my office chair, I can see it on the wall through the window. When I turn my head the other way to my right I can see the hallway where the controller is mounted at the ceiling. It’s almost direct line of site 12ft away with no obstruction other than one drywall wall. It really shouldn’t be any more simple of a direct connect to this. This device chooses to go maybe 45ft to a garage door opener, then from one far corner of the house to the farthest possible corner in the basement to a water valve controller in the basement, back up to the ground level to a 3rd device before finally “seeing” the Z-Wave controller. I’ve been in IT long enough to know that wireless is a tad confusing and a bit of a dark art form but there is no way this provides a better connection than simply connecting directly to the Z-Wave controller. Sure they’re connected but at what battery life cost due to poorly optimized rx/tx? I’ve got a couple others that look a bit odd but I’m not sure how to go about resolving. Should I just go into these few devices that look a bit messy individually and tell them to renegotiate the path that they take or what is the best way to resolve things?
► Item #5: I had some integrations that HA found that I ignored because I was tired of seeing them every time I opened up the dashboard. I don’t think I need to add these but maybe I’m missing something that would be useful or possibly something that would help with any of the above or how I interact with things that would be easier. There were quite a few items (Smart TVs, Printers, etc.) but the three I wanted to know about specifically were: tubeszb-zw zha, tubeszb-zw, esphome. Am I missing anything by not installing these or was I right to just hide them and move on?
