Heyhey
Im using HaOS on an intel nuc.
This PC has got 3 USB (version 3) ports.
One of them is used for an Homematic IP stick. On another one Ive got a mains powered USB switch, where my Sonoff Dongle E - for zigbee - is plugged in.
So one USB slot is remaining.
But I want to integrate a USV. Am not sure this is called in english that way.
USV means a mains powered battery that runs my HomeAssistant on battery, if the mains power is gone.
This guy has an USB connection to read its values.
And I want to get a newer nucki lock with matter over thread. (I do not have an existing matter network so far).
Ofcourse I can use this lock via mqtt (and via Wifi then), but I think it would be better to have it running vie Thread/Matter as I dont need the router running to get its data.
And im a big fan of zigbee, but sooner or later ill need a Matter network anyway.
So in short, I want to use 2 USB devices and have only one unused USB slot.
Is it any problem, if I use my USB hub to plug more than one device?
Yes. I do have a mains powered USB hub with multiple ports (4 ports I think), where actually only my zigbee stick is in.
I wasnt sure if its ok putting more devices (coordinators especially) into this hub.
As I need to tell homeassistant (or z2m and thread) the path of the coordinator (port: /dev/ttyUSB0) for example.
If I put 2 coordinators into the same USB hub this address is the same, isnt it?
This does not cause any conflicts?
So no prpblem at all.
And I should change my naming in any case.
Thank you very much :))
If you allow there is one (offtopic) question, driving me crazy, as I cant find anything to it.
There are a lot of zigbee setup guides around, i think all of them can be used for thread, too. As its basically the same, I should have same problems (e.g. wifi interferance).
But I cant find anything concearning Zigbee and Thread parallel.
Thise two networks should interfere each other. Or is this no problem, aslong I use different channels?
Do you maybe know a link?
