Hi, I have an 8GB Raspberry Pi 4B. I've installed Haos on three SD cards and one SSD, and I've powered it with a PC power supply. In all cases, I get the same error: it starts loading the homepage /onboarding.html but never finishes and doesn't display anything on port 8123. On port 4357, it displays a page saying "Supervisor: Connected," "Support: Supported," and "Health: Healthy," but it just keeps loading endlessly. I also installed an RPOS as a web server to rule out a network or hardware problem, and it worked perfectly. The Haos version is 17.3; I also tried 17.0. Even the AI ​​hasn't been able to help. I think I've tried them all.
How long did you wait before you bailed and tried again. Taking more than an hour is not unheard of with a Pi...
What do you mean by PC power suppl;y? If plugged into the usb port on a PC that will almost certainly be the issue, get a proper 3a+ supply for it.
Post a picture of the error you're seeing.
Sà primero intenté con el cargador oficial de 3Ah pero da el mismo problema, me parece que hay incompatibilidad de esta placa con homeassistant actual tengo la RP4b de 8gb con EEPROM 138c0 la ultima y actualicé el BOOTLOADER al 17 may 2026, dicen que la version 15.3 fue estable pero ya no esta disponible.
No muestra error simplemente queda colgado en el puerto 8123 aunque carga el nombre de las primera pagina /onboarding.html no muestra nada más y en el puerto 4357 muestra la pagina con los datos pero sigue indicando que esta cargando.
