I just got an update ro HA companion Now it's unable to connect
I’m able to connect via Chrome, and it was working fine earlier today. My adroid phone is connected via wifi to the same network as my home-assistant instance. I’m using the same ip and port as the one that’s working on Chrome. My configuration.yaml shows the ip address range of my lan under trusted networks. There’s nothing in the Core, supervisor or DNS logs. I already forces a stop on tha companion app to no effect. I’m at a loss here.
I rebooted the phone and the companion app is working for whatever reason…
Hi, please take the time to mark the post with the solution as the answer, you do that by selecting the three dots under the post:
Then select the check box:
By doing so:
  • this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
  • this prevents that someone else steps in trying to help
Thanks for giving back to the community! :+1:
