I have a decentralized ventilation central controller SEC-Touch in my house and have been looking for a long time for a way to integrate it with the home assistant.
The company itself sells a “gateway” that can be used to control the fans, but it NEEDS internet to work. Something I really don’t like for a +200 euro device.
So I’ve been working on my first external ESPHome component for a few months to be able to control the device, and now I have the first working version.
Right now it can only control the speed of the fans, or put them in special “speed states” like “time” or “storm”, but if you integrate it into the home assistant, all the other functions aren’t really needed.
thank you so much for publishing this project. Getting my dumb SEVi 160 integrated into Home Assistant has been on top of my smart home wish list for long time.
I have already contacted the manufacturer and asked them if they would be willing to add an integration to Home Assistant. Unsurprisingly there hasn’t been any positive feedback and they recommended buying their overpriced cloud-brick
Right after seeing your post I got really excited and ordered the ESP you linked in your GitHub repo through AZdelivery.
I’m now facing two problems.
The first being, when I install the program using ESPHome the webserver on the device is correctly installed and I can visit the UI using my browser. But as soon as I reboot the device, the program is wiped from the ESP. Well, for the time being I worked around it simply wiring up the ESP with the SEC Touch and then installing the program OTA.
The bigger problem I’m facing is, the program simply doesn’t seem to do anything. I can alter the settings in the UI as much as I like, the fans of my ventilation system just stay on the same level and also the SEC Touch UI won’t show any changed values.
Here is the some of the output of my log:
[15:41:33][C][api:140]: API Server:
[15:41:33][C][api:141]: Address: wroom32.local:6053
[15:41:33][C][api:143]: Using noise encryption: YES
[15:41:35][D][sec-touch:041]: SEC-Touch update
[15:41:35][D][sec-touch:307]: No property ids are registered for recursive tasks
[15:41:35][D][sec-touch:277]: process_get_queue "data-get-queue" with size 30
[15:41:35][D][sec-touch:283]: Task targetType "LABEL" and property_id "78"
[15:41:35][D][sec-touch-uart:357]: send_get_message
[15:41:35][D][sec-touch-uart:366]: buffer 32800 78 35235
[15:41:40][D][sec-touch:041]: SEC-Touch update
[15:41:40][D][sec-touch:307]: No property ids are registered for recursive tasks
[15:41:40][D][sec-touch:277]: process_get_queue "data-get-queue" with size 36
[15:41:40][D][sec-touch:283]: Task targetType "LABEL" and property_id "78"
[15:41:40][D][sec-touch-uart:357]: send_get_message
[15:41:40][D][sec-touch-uart:366]: buffer 32800 78 35235
[15:41:45][D][sec-touch:041]: SEC-Touch update
[15:41:45][D][sec-touch:307]: No property ids are registered for recursive tasks
[15:41:45][D][sec-touch:277]: process_get_queue "data-get-queue" with size 42
[15:41:45][D][sec-touch:283]: Task targetType "LABEL" and property_id "78"
[15:41:45][D][sec-touch-uart:357]: send_get_message
[15:41:45][D][sec-touch-uart:366]: buffer 32800 78 35235
[15:41:50][D][sec-touch:041]: SEC-Touch update
[15:41:50][D][sec-touch:307]: No property ids are registered for recursive tasks
[15:41:50][D][sec-touch:277]: process_get_queue "data-get-queue" with size 48
[15:41:50][D][sec-touch:283]: Task targetType "LABEL" and property_id "78"
[15:41:50][D][sec-touch-uart:357]: send_get_message
[15:41:50][D][sec-touch-uart:366]: buffer 32800 78 35235
[15:41:55][D][sec-touch:041]: SEC-Touch update
[15:41:55][D][sec-touch:307]: No property ids are registered for recursive tasks
[15:41:55][D][sec-touch:277]: process_get_queue "data-get-queue" with size 54
[15:41:55][D][sec-touch:283]: Task targetType "LABEL" and property_id "78"
[15:41:55][D][sec-touch-uart:357]: send_get_message
[15:41:55][D][sec-touch-uart:366]: buffer 32800 78 35235
[15:42:00][D][sec-touch:041]: SEC-Touch update
[15:42:00][D][sec-touch:307]: No property ids are registered for recursive tasks
[15:42:00][D][sec-touch:277]: process_get_queue "data-get-queue" with size 60
[15:42:00][D][sec-touch:283]: Task targetType "LABEL" and property_id "78"
[15:42:00][D][sec-touch-uart:357]: send_get_message
[15:42:00][D][sec-touch-uart:366]: buffer 32800 78 35235
[15:42:05][D][fan:021]: 'Fan 6' - Setting:
[15:42:05][D][fan:024]: State: ON
[15:42:05][D][fan:030]: Speed: 11
[15:42:05][D][SecTouchFan:107]: Control called
[15:42:05][D][SecTouchFan:121]: New state to 1
[15:42:05][D][SecTouchFan:126]: Setting speed to 11
[15:42:05][I][SecTouchFan:149]: [Update for 178] - [] speed: 11
[15:42:05][D][sec-touch:352]: add_set_task
[15:42:05][I][SecTouchFan:153]: Publishing state of FAN
[15:42:05][D][fan:120]: 'Fan 6' - Sending state:
[15:42:05][D][fan:121]: State: ON
[15:42:05][D][fan:123]: Speed: 11
[15:42:05][D][text_sensor:064]: 'Mode Fan 6': Sending state 'Unknown'
[15:42:05][W][component:237]: Component web_server took a long time for an operation (79 ms).
[15:42:05][W][component:238]: Components should block for at most 30 ms.
[15:42:08][D][fan:021]: 'Fan 6' - Setting:
[15:42:08][D][fan:024]: State: ON
[15:42:08][D][fan:030]: Speed: 1
[15:42:08][D][SecTouchFan:107]: Control called
[15:42:08][D][SecTouchFan:121]: New state to 1
[15:42:08][D][SecTouchFan:126]: Setting speed to 1
[15:42:08][I][SecTouchFan:149]: [Update for 178] - [] speed: 1
[15:42:08][D][sec-touch:352]: add_set_task
[15:42:08][I][SecTouchFan:153]: Publishing state of FAN
[15:42:08][D][fan:120]: 'Fan 6' - Sending state:
[15:42:08][D][fan:121]: State: ON
[15:42:08][D][fan:123]: Speed: 1
[15:42:08][D][text_sensor:064]: 'Mode Fan 6': Sending state 'Unknown'
[15:42:08][W][component:237]: Component web_server took a long time for an operation (82 ms).
[15:42:08][W][component:238]: Components should block for at most 30 ms.
[15:42:27][I][safe_mode:041]: Boot seems successful; resetting boot loop counter
[15:42:27][D][esp32.preferences:114]: Saving 1 preferences to flash...
[15:42:27][D][esp32.preferences:142]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[15:42:32][D][api:103]: Accepted 192.168.178.84
[15:42:32][W][api.connection:092]: : Socket operation failed: BAD_INDICATOR errno=11
[15:42:52][D][fan:021]: 'Fan 1' - Setting:
[15:42:52][D][fan:024]: State: ON
[15:42:52][D][fan:030]: Speed: 11
[15:42:52][D][SecTouchFan:107]: Control called
[15:42:52][D][SecTouchFan:121]: New state to 1
[15:42:52][D][SecTouchFan:126]: Setting speed to 11
[15:42:52][I][SecTouchFan:149]: [Update for 173] - [] speed: 11
[15:42:52][D][sec-touch:352]: add_set_task
[15:42:52][I][SecTouchFan:153]: Publishing state of FAN
[15:42:52][D][fan:120]: 'Fan 1' - Sending state:
[15:42:52][D][fan:121]: State: ON
[15:42:52][D][fan:123]: Speed: 11
[15:42:52][D][text_sensor:064]: 'Mode Fan 1': Sending state 'Unknown'
[15:42:52][W][component:237]: Component web_server took a long time for an operation (77 ms).
[15:42:52][W][component:238]: Components should block for at most 30 ms.
[15:42:54][D][fan:021]: 'Fan 1' - Setting:
[15:42:54][D][fan:024]: State: ON
[15:42:54][D][fan:030]: Speed: 1
[15:42:54][D][SecTouchFan:107]: Control called
[15:42:54][D][SecTouchFan:121]: New state to 1
[15:42:54][D][SecTouchFan:126]: Setting speed to 1
[15:42:54][I][SecTouchFan:149]: [Update for 173] - [] speed: 1
[15:42:54][D][sec-touch:352]: add_set_task
[15:42:54][I][SecTouchFan:153]: Publishing state of FAN
[15:42:54][D][fan:120]: 'Fan 1' - Sending state:
[15:42:54][D][fan:121]: State: ON
[15:42:54][D][fan:123]: Speed: 1
[15:42:54][D][text_sensor:064]: 'Mode Fan 1': Sending state 'Unknown'
[15:42:54][W][component:237]: Component web_server took a long time for an operation (74 ms).
[15:42:54][W][component:238]: Components should block for at most 30 ms.
Can you give me any advice on what I can do to get this thing to work?
The SEC Touch device you own (judging from the image in your repo) and the the one I have have the exact same model type number - so hardware differences shouldn’t be much of an issue here.
Have you changed the GPIO pins? RX is 3 and TX is 1, which is different than the OPs GitHub page as you have an ESP32 rather than an 8266 used in the GitHub page.
Can you post your full yaml file? changing anything anything private to xxxx.
The example uses (and I) use GPIO17 and GPIO16. The other one is for the serial logger (AFAIK). This the config I use (I load the component from a local folder):
[08:34:28][I][app:100]: ESPHome version 2025.2.2 compiled on Mar 17 2025, 08:33:02
[08:34:35][I][SecTouchFan:149]: [Update for 178] - [] speed: 11
[08:34:35][I][SecTouchFan:153]: Publishing state of FAN
[08:34:38][W][api.connection:092]: : Socket operation failed: BAD_INDICATOR errno=11
[08:34:39][I][SecTouchFan:149]: [Update for 178] - [] speed: 1
[08:34:39][I][SecTouchFan:153]: Publishing state of FAN
[08:34:52][I][SecTouchFan:149]: [Update for 177] - [] speed: 1
[08:34:52][I][SecTouchFan:153]: Publishing state of FAN
[08:34:55][I][SecTouchFan:149]: [Update for 176] - [] speed: 1
[08:34:55][I][SecTouchFan:153]: Publishing state of FAN
[08:34:57][I][SecTouchFan:149]: [Update for 175] - [] speed: 1
[08:34:57][I][SecTouchFan:153]: Publishing state of FAN
[08:35:00][I][SecTouchFan:149]: [Update for 174] - [] speed: 1
[08:35:00][I][SecTouchFan:153]: Publishing state of FAN
[08:35:02][I][SecTouchFan:149]: [Update for 173] - [] speed: 1
[08:35:02][I][SecTouchFan:153]: Publishing state of FAN
[08:35:03][I][SecTouchFan:149]: [Update for 173] - [] speed: 1
[08:35:03][I][SecTouchFan:153]: Publishing state of FAN
[08:35:06][I][SecTouchFan:149]: [Update for 174] - [] speed: 1
[08:35:06][I][SecTouchFan:153]: Publishing state of FAN
[08:35:08][I][SecTouchFan:149]: [Update for 175] - [] speed: 1
[08:35:08][I][SecTouchFan:153]: Publishing state of FAN
[08:35:09][I][SecTouchFan:149]: [Update for 176] - [] speed: 1
[08:35:09][I][SecTouchFan:153]: Publishing state of FAN
[08:35:16][I][SecTouchFan:149]: [Update for 177] - [] speed: 1
[08:35:16][I][SecTouchFan:153]: Publishing state of FAN
[08:35:23][I][safe_mode:041]: Boot seems successful; resetting boot loop counter
[08:35:38][W][api.connection:092]: : Socket operation failed: BAD_INDICATOR errno=11
[08:36:39][W][api.connection:107]: : Reading failed: BAD_INDICATOR errno=11
[08:37:39][W][api.connection:092]: : Socket operation failed: BAD_INDICATOR errno=11
I tried that - didn’t change anything
Is your software version the same as mine?
Is there anything I can do to cancel out any potential errors? I measured the voltage of the PC interface of the SEC Touch. It’s around 3,2V. The RX and TX jump around in intervals so the board is not dead or anything.
I also tried using my D1 mini altering the ESPHome platform accordingly. Same results
The jumper cables shouldn’t be the problem, right?! As a power source I’m using an old 5V/1A iPhone charger.
My device SW versions ends with G instead of E like yours. But to be honest I do not think that is the problem. I am not at me computer right now. Can you put everything on debug and see if you get UART data?
I am not using jumper cables but a connector my friend gifted to me, but I am not sure of the name of it.
You could also try another GND pin. I have had esp32 boards where a GND pin was not connected to the rest.
You could also swap the rx/tx pins, just in case they are swap on your device. I think it will not break anything (I Think)
I also bought a connector for the SEC-Touch PC interface and screwed in the male jumper cables.
Tried another GND pin → no luck
Tried switching the RX/TX (YOLO ) and the debug data went crazy:
[00:19:09][D][sec-touch:061]: SEC-Touch loop Data available
[00:19:09][D][sec-touch:163]: [handle_uart_input_for_get_queue]--------
[00:19:09][D][sec-touch-uart:176]: Byte received: 0
[00:19:09][D][sec-touch-uart:211]: saving into buffer without id or value
[00:19:09][D][sec-touch-uart:176]: Byte received: 224
[00:19:09][W][sec-touch:191]: Starting to store message but the data is not ACK. Discarding data: 224
[00:19:09][D][sec-touch-uart:176]: Byte received: 28
[00:19:09][W][sec-touch:182]: Starting to store message but the data is not ACK in the second attempt. Discarding all data: 28
[00:19:09][W][sec-touch:191]: Starting to store message but the data is not ACK. Discarding data: 28
[00:19:09][W][sec-touch:182]: Starting to store message but the data is not ACK in the second attempt. Discarding all data: 0
[00:19:09][W][sec-touch:191]: Starting to store message but the data is not ACK. Discarding data: 0
[00:19:09][C][restart.button:017]: Restart Button 'Restart'
[00:19:09][C][restart.button:017]: Icon: 'mdi:restart'
I guess that is nothing to get excited about. The web interface still shows Unknown as a state for all fans.
Ah yes, those logs indicate that the data send is not valid.
This is new to me. I used an old one from two I purchased a couple of years ago. I just revised and the other one I have also uses esp32dev, I use it connected to an led strip with bluetooth and a temp sensor.
Do you maybe have another board to test? any Wroom should work AFAIK. I do not like that comment that said that the baud rate needed to be changed. Although maybe the comment talks about the external hardware.
Can you check what you get in the logs with the regular UART connection?
I am also no professional with the hardware part () but if I had that problem I would try to connect the board to my laptop instead of the charger and try to get logs since boot. While I was doing the component I did that applying OTA updates while having the device connected to my laptop. There are serial comm apps that help with that.
@distante sorry, I don’t get proper notifications for this board. Unfortunately not. I tried it with a couple of other boards. Sadly my laptop has a broken display so I can only use it hooked up to my monitor not located near the SEV so I can’t really log the UART locally
Kind of lost hope but deep inside I still really want this to work. I’ll give it another try soon and report back here however it went. Are there other users that got it working?!
I am currently kind of overwhelmed with work but when I have the time I want to recheck the code. I can not exclude that I have some errors there since this is the first time I did something with ESPHome C++ part.
@VeryDisco I fixed the problem (partially). To be honest it also was broken on my side and I did not noticed because my wife was changing the stuff manually.
I still need to learn how to create unit or integration tests for this stuff.
The device sometimes sends random “single” 255 values and I still do not determine what are those. My error was that I considered noise and discard them hardly but I also removed “correct” ones.
There is still one problem (that is the partially part) that sometimes the chip resets. If what this says is correct, it is due logging and keeping it off for the component should be enough.
In any case, the reset takes some seconds and the ESP32 correctly restores the values from SECTouch.
Hi @distante thank you for your efforts. Somehow I don’t get notifications from this forum - could be a spam filter issue. I noticed some PRs being merged and thought I’d check back here. I will retry my setup in the next few days and report back here. Cheers, Lorenz
