I need config help for my ultrasonic sensor
So I got myself an Ultrasonic Sensor from DFRobot.
In creating the YAML I borrowed some entity configuration from the Athom Tech Garage Door Openers yaml code I installed a while ago.
I have the ultrasonic sensor connected to an ESP8266 board. I’m using the 4 pin from the bottom right of the pin out diagram linked here.
I even tried swapping the Rx & Tx wires thinking I might have mixed them up. All the other entities show up but NOT the distance (which is the whole purpose of the device).
Where did I go wrong in the YAML code?
esphome:
  friendly_name: ESP_ZZ_OS_Well_8266
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX="
ota:
  - platform: esphome
wifi:
  networks:
  - ssid: !secret wifi_ssid
  - ssid: !secret 2_wifi_ssid
    password: !secret 2_wifi_password
  manual_ip:
    static_ip: 192.168.0.232
    gateway: 192.168.0.1
    subnet: 255.255.255.0
  ap:
web_server:
  version: 2
captive_portal:
uart:
  tx_pin: GPIO1
  rx_pin: GPIO3
  baud_rate: 9600
  - platform: "a01nyub"
    entity_category: diagnostic
    unit_of_measurement: 'cm'
    icon: "mdi:water-percent"
    device_class: distance
    state_class: measurement
    accuracy_decimals: 2
    filters:
      - throttle: 60s
      - heartbeat: 60s
      - quantile:
          window_size: 7
          send_every: 4
          send_first_at: 3
  - platform: uptime
    internal: true
  - platform: wifi_signal
    name: "WiFi Signal dB"
    update_interval: 60s
    entity_category: "diagnostic"
  - platform: copy
    source_id: wifi_signal_db
    name: "WiFi Signal Percent"
    filters:
      - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
    unit_of_measurement: "Signal %"
    device_class: ""
button:
  - platform: restart
    entity_category: config
  - platform: factory_reset
  - platform: safe_mode
    internal: false
light:
  - platform: status_led
    disabled_by_default: true
    pin:
      inverted: true
      number: GPIO0
text_sensor:
  - platform: wifi_info
    ip_address:
    ssid:
    mac_address:
  #  Creates a sensor showing when the device was last restarted
    icon: mdi:clock
  #  Creates a sensor of the uptime of the device, in formatted days, hours, minutes and seconds
    lambda: |-
      int seconds = (id(uptime_sensor).state);
      int days = seconds / (24 * 3600);
      seconds = seconds % (24 * 3600);
      int hours = seconds / 3600;
      seconds = seconds % 3600;
      int minutes = seconds /  60;
      seconds = seconds % 60;
      if ( days > 3650 ) {
        return { "Starting up" };
      } else if ( days ) {
        return { (String(days) +"d " + String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
      } else if ( hours ) {
        return { (String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
      } else if ( minutes ) {
        return { (String(minutes) +"m "+ String(seconds) +"s").c_str() };
      } else {
        return { (String(seconds) +"s").c_str() };
    icon: mdi:clock-start
time:
  - platform: sntp
  # Define the timezone of the device
    timezone: America/Halifax
  # Change sync interval from default 5min to 6 hours (or as set in substitutions)
    #update_interval: ${sntp_update_interval}
  # Set specific sntp servers to use
    servers:
      - 0.pool.ntp.org
      - 1.pool.ntp.org
      - 2.pool.ntp.org
  # Publish the time the device was last restarted
    on_time_sync:
      then:
        # Update last restart time, but only once.
        - if:
            condition:
              lambda: 'return id(device_last_restart).state == "";'
            then:
              - text_sensor.template.publish:
                  state: !lambda 'return id(sntp_time).now().strftime("%a %d %b %Y - %I:%M:%S %p");'
If you try to use rx/tx pins with your setup, you need to disable serial logging.
logger:
  baud_rate: 0
But some Esp8266 boards are designed wrong and you can’t actually use rx/tx pins. In that case set uart pins to Gpio4/5. It will use softwareserial, but with 9600 kbps it’s ok.
So I switched the logger baud rate to 0 and the pins to GIO4 & GPIO5. It at least displays a distance sensor now. But it’s stuck at 1.89 cm and keeps displaying this on the ESPHome web server log screen:
12:47:14 [W] [a01nyub.sensor:033]
Invalid data read from sensor: FF.00.FA.F9
Suggestions?
No.
Check that your wiring is solid and short.
That looks valid to me, maybe checksum F9 is incorrect…
Distance 00.FA would be 250mm.
Is it always the same or changing?
