I’m trying to create a sensor that will tell if my 3d printer is safe to shut down or not…
in the template editor I have
{% if is_state('switch.3d_printer', 'off') %}
Off
{% elif is_state('sensor.octoprint_current_state', 'Printing') %}
Not Safe
{% elif states('sensor.octoprint_actual_tool0_temp')|int <= 29 %}
Safe
{% else %}
Not Safe
{% endif %}
and it works… how ever when I try and add it to a template sensor it returns “unavailable” as soon as the octoprint_curent_state changes from “printing” to anything else.
in a seperate templates.yaml file I have
- name: Ender Safe Shutdown
state: >
Off
Not Safe
Safe
{% else %}
Not Safe
{% endif %}
can anyone please help me with where I am going wrong?
this is what i have now ( i hope i understood you properly)
state: >
Off
Not Safe
Safe
{% else %}
Not Safe
{% endif %}
I checked the configuration and it came up ‘Configuration good’ in green, however there is no change,
if switch.3d_printer is off the sensor shows ‘off’
if sensor.octoprint_current_state is ‘Printing’ it shows ‘Not Safe’
but as soon as sensor.octoprint_current_state changes the sensor shows ‘unavailable’
For example, if the int filter encountered a value it could not convert (such as unknown or unavailable) it would fail (and log an error ) because the int filter lacks a default value.
In the following example, the int filter contains a default value of 100 (but you should set it to whatever you think is best for your application):
