stratfin
(Rob )
February 16, 2026, 8:15pm
1
Newbie HA user here. I need some advice on what I think is a more complex automation.
In my kitchen I have 2 sets of lights that are controlled by motion. I have a number of different scenarios and was wondering if I could do this all in one automation or do I need to set up separate automations for each scenario.
The 2 sets of lights are:
Main Kitchen Lights which are on a dimmer
Island Light which is on an on/off switch.
I have 3 helper toggles:
Home Mode
Watching TV
Night Mode
Senario 1:
When motion is detected and Home Mode is on and Watching TV is off and Lux is <200 turn on Island Light and Main Lights 100%
When motion is detected and Home Mode is on and Watching TV is off and Lux is >200 and < 300 turn on Island Light (no Main Lights)
When motion is detected and Home Mode is on and Watching TV is off and Lux is >300 no lights turn on.
When no motion is detected for 10 min turn off the lights.
Senario 2:
When motion is detected and Watching TV is on turn on Main Lights 50% (no Island Light)
When no motion is detected for 5 min turn off the lights.
Senario 3:
When motion is detected and Night Mode is on turn on Main Lights 5% (no Island Light)
If this can be done with one automation would some please let me know how to do it.
Thanks.
Yes, it can be done in one automation. But, since you are new to HA, it might be best to start by doing it with separate automations first. Once you get them working the way you want, if you still want to, we can help you combine them.
wgumaa
(Waleed)
February 16, 2026, 8:25pm
3
Try this:
alias: Kitchen Motion Lighting (All Modes)
mode: restart
- platform: state
entity_id: binary_sensor.kitchen_motion
to: "on"
- platform: state
to: "off"
for:
minutes: 5
- platform: state
to: "off"
for:
minutes: 10
condition: []
- choose:
# SCENARIO 3 β NIGHT MODE (Highest Priority)
- conditions:
- condition: trigger
- condition: state
entity_id: input_boolean.night_mode
state: "on"
sequence:
- service: light.turn_on
entity_id: light.main_kitchen_lights
brightness_pct: 5
# SCENARIO 2 β WATCHING TV
- conditions:
- condition: state
entity_id: input_boolean.watching_tv
state: "on"
sequence:
brightness_pct: 50
# SCENARIO 1 β HOME MODE + LUX LOGIC
- conditions:
- condition: state
entity_id: input_boolean.home_mode
state: "on"
- condition: state
state: "off"
sequence:
- choose:
# Lux < 200 β Main 100% + Island
- conditions:
- condition: numeric_state
entity_id: sensor.kitchen_lux
below: 200
sequence:
brightness_pct: 100
- service: switch.turn_on
entity_id: switch.island_light
# Lux 200β300 β Island only
- conditions:
above: 200
below: 300
sequence:
# Lux > 300 β Do nothing
- conditions:
above: 300
sequence: []
# TURN OFF LOGIC β NIGHT + TV (5 min)
- conditions:
sequence:
- service: light.turn_off
- service: switch.turn_off
# TURN OFF LOGIC β NORMAL MODE (10 min)
- conditions:
sequence:
stratfin
(Rob )
February 18, 2026, 12:03am
4
Thanks. As I mentioned, Iβm a HA newbie. Do I copy this, create a new automation, select βEdit in YAMlβ and paste it there?
Also I guess I should change the entity IDs to match what I have.
Yes you can do just that, paste as YAML. Replace the devices with your actual ones as well.
wgumaa
(Waleed)
February 18, 2026, 7:19am
6
yes and then change your entities. you can switch back to visiual mode to that as it may be easier
stratfin
(Rob )
February 19, 2026, 8:10pm
7
Thank you. This is working just fine. (Iβm going to copy and adjust it for other lighting in my home).
Question; will the lights turn off after no motion when the lights are turned on manually - not by motion? Iβm coming from Apple Home and its motion activated automations will only turn off the light if motion turned it on.
stratfin
(Rob )
February 20, 2026, 8:35pm
8
How does the automation know which turn off logic to use?
wgumaa
(Waleed)
February 21, 2026, 7:44am
9
stratfin:
With your current automation, the lights will turn off after no motion even if they were turned on manually.
wgumaa
(Waleed)
February 21, 2026, 7:49am
10
The automation has trigger ids. So when the automation runs it is asking itself:
Which trigger fired me?
Then it looks at the condition.
Looking back at it, I refined it a bit:
mode: restart
- platform: state
to: "on"
- platform: state
to: "off"
for:
minutes: 5
condition: []
- choose:
- conditions:
- condition: state
state: "on"
sequence:
brightness_pct: 5
- conditions:
- condition: state
state: "on"
sequence:
brightness_pct: 50
- conditions:
- condition: state
state: "on"
- condition: state
state: "off"
- condition: state
state: "off"
sequence:
- choose:
# Lux < 200 - Main 100% + Island
- conditions:
below: 200
sequence:
brightness_pct: 100
# Lux 200 - 300 -Island only
- conditions:
above: 199
below: 301
sequence:
# Lux > 300 - Do nothing
- conditions:
above: 300
sequence: []
# TURN OFF LOGIC
- conditions:
sequence:
# If night mode OR watching TV - off after 5 min
- choose:
- conditions:
- condition: or
conditions:
- condition: state
state: "on"
- condition: state
state: "on"
sequence:
# Otherwise - wait extra 5 min (total 10) then off
default:
- delay: "00:05:00"
# Safety: only turn off if motion is still off after the extra delay
- condition: state
state: "off"
