I (think) I have an OpenTherm heating system and I would like to make it smart without replacing the existing room unit
Hi everyone.
We have gas central heating made by ATAG. It’s the ATAG Q25S.
The room unit is a BrainQ RSC/6.
Replacing the BrainQ with an ATAG One would cost several hundred euros, so I’m exploring cheaper options. Also I like the BrainQ very much. It’s retro, it’s tactile and it has character.
Is it possible to somehow retrofit “smartness” with an OpenTherm gateway or something? Like hook it inbetween the room unit and the gas burner?
Ideally I would want to use both the Home Assistant integration as well as the room unit itself to read the current status as well as change the modes, timers etc.
Any pointers on where to look? Would it even be possible?
Greetings
Use the search function :slight_smile:
If OperTherm is supported/used then there is this:
I have exactely the same roomunit and it works with the device linked above.
Tatsache!
Is Gateway mode read only?
Can OT Thing change settings which will then show up on the room unit as well? Like for example setting the heating to standby mode via an automation and then back to auto via the room unit?
EDIT: Sounds like “repeater” is close to what I’m looking for. Question is: can it only intercept/override whatever is input in the room unit or can you change settings directly (via MQTT or the web interface) as well which would then update the interface on the room unit?
I think I’ll order one anyway.
EDIT: Gekauft! Freue mich drauf!
Settings of the roomunit can not be change in it from bus side, but some control values can be overriden by the OTthing
