I want to create a template binary sensor from 2 binary sensors, put code like this doesn't work, how should i fix the code?
I want to create a template binary sensor from 2 binary sensors, put code like this doesn’t work, how should i fix the code?
esphome:
platform: ESP8266
board: nodemcuv2
logger:
ota:
password: “12345678”
wifi:
networks:
  • ssid: SideParkingCH6
    password: 12345678
  • ssid: WashAreaCH2
    password: 12345678
  • ssid: Kitchen
    password: 12345678
  • ssid: TendaCH2
    password: 12345678
  • ssid: kaokai
    password: 12345678
ap:
ssid: “motion-am312-pavillion”
captive_portal:
web_server:
port: 80
api:
reboot_timeout: 5min
  • platform: wifi_signal
    name: motion am312 pavillion Wifi Signal
    update_interval: 10s
  • platform: uptime
    name: motion am312 pavillion Uptime
switch:
  • platform: restart
binary_sensor:
  • platform: gpio
    pin: D8
    name: “mts am312 pavillion d1”
    device_class: motion
  • platform: gpio
    pin: D2
    name: “mts am312 pavillion d2”
  • platform: gpio
    pin: D7
    name: “mts am312 pavillion d7”
  • platform: gpio
    pin: D0
    name: “mts am312 pavillion d0”
  • platform: gpio
    pin: D5
    name: “mts am312 pavillion d5”
  • platform: gpio
    pin: D6
    name: “mts am312 pavillion d6”
  • platform: template
    name: “mts pavilion combile”
    lambda: |-
    if (id(mts am312 pavillion d0).state = true) & (id(mts am312 pavillion d7).state = on)
    return true;
    if (id(mts am312 pavillion d0).state = false) & (id(mts am312 pavillion d7).state = false)
    return false;
I have moved your post to the correct category, could you now please edit your post and format your config correctly.
From what I can see from your incorrectly formatted code, you have not given those binary_sensors an id: (id is not the same as name)
thank you :grinning: :grinning: :grinning:
