I would like to get Home assitant to run from a large drive, as I can have my media for Plex on that drive. I have tried to clone my existing installation to this new disc, I hav tried to make a complete new installation, but it will not boot from this disc.
Is there any issues with HA OS and very large drives ?
Or is it possible to mount this drive as an second disc as it’s done in a plain linux installation ?
Ok, My system are a NUC homeassitant operation system setup on a standard intel i3 , intel B460 chipset, 16GB Ram, a 240GB SSD with the system on connected on SATA port 0, the empty 8TB disc is on SATA 1.
I have already set up the dist in one partition with ext4 filesystem, it shows up as sdb1 in the /dev catalog.
So I need to now how to get this mapped up either in the /media or /share catalog.
using /media or /share is highly NOT recommended, that is generally for removable media. You want to use fstab to set up a static mount point, something line:
When I edit the fstab i can find in the Teminal addon, it’s not there after an reboot.
When I edit the fstab in the OS, it’s surviving a rebboot, but I can’t find the mount point anywhere in the file system
What I after is to have all my media files on sdb1, not on sda. due to aviable space. both files for the inbuild mediaplayer and the plex server, and all should accessable throu samba so I easily moves files to this plex server from other computers on my network
