Until the last update the icons had a kind of bleu color, when the state was âoffâ and a kind of yellow when the state was âonâ.
Now the icon is black or white (depening on de day or night mode of the device) when the state is âoffâ and still yellow when the state is âonâ.
Looks like:
Thanks for your sugestion, I will go to try it out. Strange that I now need to specify the value foor on/off and earlier it was not needed. But anyway, if thatâs the trick: ok!
To answer your questions:
I am not actively using a theme. The âdefaultâ is selected
I only showed the code of the bulb, but there are a lot more devices included in the card at the same way. Faar too much to copy to here.
The odd code is because on that part of the card I do not want to hav e reaction on a tap, on other parts I do want it, there is the tap/double-tap action specified
In the latest HA release, some css variable have been removed. Is it possible that you where using some paper-* css variables for either card-mod or a custom theme? Happened the same to me after updating
