Identify Fibaro Devices
I have a couple of Fibaro FGSD002 devices which for any reasons have lost their “Area” setting.
I tried ping from HA but no lights appear on the device. Also I tried check network range from the devices but no log for such operation appear in HA.
Is there a way I can identify them from HA so that I can set the area setting back?
If you use ZWaveJS you can use the logs there. You could trigger the smoke sensor (usually three taps on the button) and see what comes up in the logs.
Thank you. Unfortunately, nothing seemed to work. I couldn’t find any identifying logs.
I ended up taking the sensors into the fridge for a couple of minutes and identify them with their temperature monitor…
