Not sure how useful this will be, since it’s quite specific to my setup. That’s why I only posted the screenshot so that people can use the main idea.
But in any case, here’s the json for my current automation (it has evolved since I posted the screenshot).
[{"id":"fa7cf36b71729e87","type":"server-state-changed","z":"4d4a64331b17df94","name":"Is Plex running","server":"97bbe632.da4568","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"media_player.plex_plex_for_lg_lg_oled55c8pla","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"playing","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":"5","forType":"num","forUnits":"seconds","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":220,"y":500,"wires":[["1b09138e2ce6289e"],[]]},{"id":"d487201a4d31aa70","type":"server-state-changed","z":"4d4a64331b17df94","name":"Scene TV Nightlight","server":"97bbe632.da4568","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_select.tv_lights","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":310,"y":740,"wires":[["0587c7ea9815c879"]]},{"id":"0587c7ea9815c879","type":"switch","z":"4d4a64331b17df94","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Fireplace","vt":"str"},{"t":"eq","v":"Lime","vt":"str"},{"t":"eq","v":"Neon","vt":"str"},{"t":"eq","v":"Pinky","vt":"str"},{"t":"eq","v":"Purple","vt":"str"}],"checkall":"true","repair":false,"outputs":5,"x":530,"y":740,"wires":[["a42f71ab33233c05"],["2ef89281c823c19a"],["f8d0d8eaf8f65be5"],["6ec5b6d85b40c027"],["58e5424e4ab65bcd"]]},{"id":"a42f71ab33233c05","type":"change","z":"4d4a64331b17df94","name":"Fireplace","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"light\":{\"brightness_pct\":20,\"rgb_color\":[255,162,42]},\"name\":\"Fireplace\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":720,"y":680,"wires":[["89ee6efe31b0974e"]]},{"id":"6d3a2ef3d1a082e7","type":"api-call-service","z":"4d4a64331b17df94","name":"Turn On Nightlight","server":"97bbe632.da4568","version":3,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"group.lights_lr_all","data":"msg.payload.payload.light","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1130,"y":780,"wires":[["ae7d719c71c26ad2","677dbdcd1e95d0b8","182a19f485ee5dda","efcdacf9a6beb41a"]]},{"id":"677dbdcd1e95d0b8","type":"api-call-service","z":"4d4a64331b17df94","name":"Turn Off Kitchen","server":"97bbe632.da4568","version":3,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.kitchen_ceiling_1, light.hallway_downstairs, light.hallway_upstairs","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1460,"y":760,"wires":[[]]},{"id":"182a19f485ee5dda","type":"api-call-service","z":"4d4a64331b17df94","name":"Turn Off Christmas Tree","server":"97bbe632.da4568","version":3,"debugenabled":false,"service_domain":"switch","service":"turn_off","entityId":"switch.home_extra_1","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1430,"y":820,"wires":[[]]},{"id":"2ef89281c823c19a","type":"change","z":"4d4a64331b17df94","name":"Lime","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"light\":{\"brightness_pct\":20,\"rgb_color\":[217,255,108]},\"name\":\"Lime\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":720,"wires":[["89ee6efe31b0974e"]]},{"id":"f8d0d8eaf8f65be5","type":"change","z":"4d4a64331b17df94","name":"Neon","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"light\":{\"brightness_pct\":20,\"rgb_color\":[146,226,255]},\"name\":\"Neon\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":760,"wires":[["89ee6efe31b0974e"]]},{"id":"6ec5b6d85b40c027","type":"change","z":"4d4a64331b17df94","name":"Pinky","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"light\":{\"brightness_pct\":20,\"rgb_color\":[255,182,217]},\"name\":\"Pinky\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":800,"wires":[["89ee6efe31b0974e"]]},{"id":"58e5424e4ab65bcd","type":"change","z":"4d4a64331b17df94","name":"Purple","rules":[{"t":"set","p":"payload","pt":"msg","to":"{\"light\":{\"brightness_pct\":20,\"rgb_color\":[200,146,255]},\"name\":\"Purple\"}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":730,"y":840,"wires":[["89ee6efe31b0974e"]]},{"id":"ae7d719c71c26ad2","type":"api-call-service","z":"4d4a64331b17df94","name":"Turn Off Hallways","server":"97bbe632.da4568","version":3,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.hallway_downstairs, light.hallway_upstairs","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1450,"y":700,"wires":[[]]},{"id":"fdbf8ef383ca632c","type":"server-state-changed","z":"4d4a64331b17df94","name":"Living Room Lights","server":"97bbe632.da4568","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"light.lr_","entityidfiltertype":"substring","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":false,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":250,"y":280,"wires":[["ca1814c13a2104e2"]]},{"id":"ca1814c13a2104e2","type":"switch","z":"4d4a64331b17df94","name":"Not changed by NodeRED","property":"data.new_state.context.user_id","propertyType":"msg","rules":[{"t":"neq","v":"1274912dddfa4fd1bdc9c44efb0287d3","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":520,"y":280,"wires":[["485f87d0e25743ab","efcdacf9a6beb41a"]]},{"id":"485f87d0e25743ab","type":"api-call-service","z":"4d4a64331b17df94","name":"Select Unknown","server":"97bbe632.da4568","version":3,"debugenabled":false,"service_domain":"input_select","service":"select_option","entityId":"input_select.tv_lights","data":"{\t \"option\": \"Unknown\"\t}","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":820,"y":200,"wires":[[]]},{"id":"1b09138e2ce6289e","type":"api-current-state","z":"4d4a64331b17df94","name":"TV Lights Unknown","server":"97bbe632.da4568","version":2,"outputs":2,"halt_if":"Unknown","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_select.tv_lights","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":470,"y":500,"wires":[["556281cbf7e34c81"],[]]},{"id":"556281cbf7e34c81","type":"function","z":"4d4a64331b17df94","name":"Get Random Scene","func":"const globalHomeAssistant = global.get('homeassistant');\nconst ha = globalHomeAssistant.homeAssistant;\n\nconst options = new Set(ha.states['input_select.tv_lights']['attributes']['options']);\noptions.delete(\"Unknown\")\n\nconst optionsArray = Array.from(options);\n\nvar rand = optionsArray[(Math.random() * optionsArray.length) | 0]\n\n//node.warn(rand)\n\nreturn { payload: rand };","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":750,"y":500,"wires":[["0587c7ea9815c879"]]},{"id":"b104e471edede5d0","type":"server-state-changed","z":"4d4a64331b17df94","name":"Random Scene Trigger","server":"97bbe632.da4568","version":3,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"input_boolean.trigger_random_tv_scene","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"for":0,"forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":500,"y":380,"wires":[["556281cbf7e34c81"],[]]},{"id":"1ee113954a761034","type":"api-call-service","z":"4d4a64331b17df94","name":"Random Scene Trigger Off","server":"97bbe632.da4568","version":3,"debugenabled":false,"service_domain":"input_boolean","service":"turn_off","entityId":"input_boolean.trigger_random_tv_scene","data":"","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1040,"y":300,"wires":[[]]},{"id":"efcdacf9a6beb41a","type":"delay","z":"4d4a64331b17df94","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":800,"y":300,"wires":[["1ee113954a761034"]]},{"id":"89ee6efe31b0974e","type":"function","z":"4d4a64331b17df94","name":"Proxy","func":"const i = msg;\n//node.warn(i);\n\nconst response = {\n \"payload\": i.payload\n};\n\nreturn { payload: response};","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":910,"y":780,"wires":[["6d3a2ef3d1a082e7","5acec8a7ad520457"]]},{"id":"5acec8a7ad520457","type":"api-call-service","z":"4d4a64331b17df94","name":"Set Dropdown","server":"97bbe632.da4568","version":3,"debugenabled":false,"service_domain":"input_select","service":"select_option","entityId":"input_select.tv_lights","data":"{\t \"option\": msg.payload.payload.name\t}","dataType":"jsonata","mergecontext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":980,"y":660,"wires":[[]]},{"id":"a7ddcde07ad20de4","type":"server-events","z":"4d4a64331b17df94","name":"Living Room/Kitchen Listener","server":"97bbe632.da4568","version":1,"event_type":"deconz_event","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"waitForRunning":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"$outputData(\"eventData\").event_type","valueType":"jsonata"}],"x":180,"y":60,"wires":[["0d6f276ba5a1e81a"]]},{"id":"0d6f276ba5a1e81a","type":"switch","z":"4d4a64331b17df94","name":"Which remote","property":"payload.event.id","propertyType":"msg","rules":[{"t":"eq","v":"switch_kitchen_wall_left","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":240,"y":160,"wires":[["a0bf2012ceed8ae9"]]},{"id":"a0bf2012ceed8ae9","type":"switch","z":"4d4a64331b17df94","name":"Wall Remote Left","property":"payload.event.event","propertyType":"msg","rules":[{"t":"eq","v":"1002","vt":"str"},{"t":"eq","v":"5002","vt":"str"},{"t":"eq","v":"7002","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":490,"y":160,"wires":[["485f87d0e25743ab"],["485f87d0e25743ab"],["485f87d0e25743ab"]]},{"id":"97bbe632.da4568","type":"server","name":"Home Assistant","version":1,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
