Identify my Philips Iris Lamp Generation
Hi everyone,
I recently bought a second-hand Philips Iris lamp with the following references on the label:
9150 043 18901
Model: 7199960PH
The lamp didn’t come with a remote, so I’m trying to reset it to pair it with Zigbee2MQTT. According to the documentation, this model should be supported. However, I’m facing two issues:
  1. I can’t get the lamp into pairing mode. I’ve followed the instructions to turn it on and off in different cycles and intervals, but nothing seems to work.
  2. The alternative methods I’ve found (e.g., using a remote or a Bridge) require devices I don’t have.
Is it possible that this specific version of the lamp isn’t compatible? How can I confirm compatibility?
If I do need a remote to pair it, which one would you recommend? Would an Ikea remote work?
Thanks in advance for your help!
