Hi all and I hope someone may be able to help with this topic.
I have this template inside a Markup Card and it works really well but I would love to be able to extend it a little and I’m really not sure how to go about it.
Here is my template:
{% if is_state("sun.sun", "above_horizon") -%}
#### Generating Solar Power: {{ (states( 'sensor.total_solar_array_power' ))|float |round (0) }} Watts
#### Feed In (-) / Purchased (+): {{ (states( 'sensor.grid_power_watts' ))|float |round (0) }} Watts
#### Purchased Energy: {{ (states( 'sensor.gosungrow_virtual_1273924_p83102' )) }} kWh
#### Feed In Energy: {{ (states( 'sensor.gosungrow_virtual_1273924_p83072' ))|float |round (0) }} kWh
#### Battery Discharging (-) / Charging: (+): {{ (states( 'sensor.battery_charge_and_discharge_watts' ))|float |round (0) }} Watts
#### Battery Storage: {{ (states( 'sensor.gosungrow_getpsdetail_1273924_storage_inverter_data_1273924_14_1_1_p13141' )|float |round (0)) }} %
#### Battery Energy Today: {{ (states( 'sensor.gosungrow_virtual_1273924_14_1_1_p13028' ))|float |round (0) }} kWh
#### Battery Current: {{ (states( 'sensor.gosungrow_virtual_1273924_43_2_1_p58602' )) }} Amps
{%- else -%}
### Battery Storage Level: {{ (states( 'sensor.gosungrow_getpsdetail_1273924_storage_inverter_data_1273924_14_1_1_p13141' )) }} %
{%- endif %}
That displays this text in the day:
Energy Status:
Generating Solar Power: 19 Watts
Feed In (-) / Purchased (+): 0 Watts
Purchased Energy: 2 kWh
Feed In Energy: 19 kWh
Battery Discharging (-) / Charging: (+): -1273 Watts
Battery Storage: 93 %
Battery Energy Today: 14 kWh
Battery Current: 3.4 Amps
Once the sun goes down it of course displays the nightime information specified in the template.
What I am looking to extend is if below line the value of Solar Power sensor was zero, then I would like to display the text “Not Generating Solar Power” or the like.
Generating Solar Power: 22 Watts
I am sure this should be possible as I can display night and day using an if - else statement I’m just not sure how to impliment what I am looking to achieve here?
Thanks in advance for any tips!
