I used google_assistant
in configuration to expose a light fubar
Where can I see fubar inside the GH app?
If you haven’t added it to your home you’ll see it at the bottom, as with any other entity. If you have then you’ll see it in the room you added it to.
I’m not sure I explained myself.
I’m talking about these 24 devices. I can’t find one HA scene I created. But it’s working when I use voice commands.
I have several scripts being passed in using the Google Assistant integration. For example
script.temporarily_disable_pihole:
name: 'Shut your pie hole'
After synchronizing I can say
Ok Google, shut your pie hole
And on HomeAssistant script.temporarily_disable_pihole
executes successfully.
But script.temporarily_disable_pihole
doesn’t appear as a device in the GoogleHome or GoogleAssistant apps. This used to work, and I have no idea when it stopped.
That sounds then like a Google side thing
Hopefully somebody who makes more use of Google Assistant than I do can help you here.
