I want to build an automation that is essentially and if else statement. It looks like this can be done with a template but being new to HA I am not understanding how the templates work and am having a hard time following the documentation.
Here is my situation. I have a a group that turns on switches that control some outside Christmas lights. I also have a group that controls outside Christmas figurine blowups. Since I am in the north where we get snow I cover the blow ups up when snow or freezing rain is in the forecast. So i have created an input boolean switch that i can toggle when the blow ups are uncovered. This way if I do not get to uncovering them or i keep them covered due to a storm they are not running if the boolean switch is off.
Here is a run down of what i am looking for with the entity names.
Trigger will be 30 mins prior to sunset
if input_boolean.blowups_good = on
than
switch.turn_on group.xmas_lights and delay 30 seconds (Due to wifi switches being turned on by group.xmas_lights) group.xmas_blowups
else
Update:
I have been able to figure out the template however I am having a problem with the delay and having it turn on two groups. As long as i have one entity ID in the true part of the statement all works fine but as soon as I add a second ID i get an error along with only adding the delay line with one ID i get an error. I am guess I just dont have the correct syntax.
- alias: Test If Else Statement for Christmas Lights
trigger:- platform: state
entity_id: switch.philsoffice_switch
to: ‘on’
service: switch.turn_on
data_template :
entity_id: >
{%- if is_state(“input_boolean.blowups_good”, “on”) -%}
group.xmas_lights
delay: 00:00:30
group.xmas_blowups
{%- else -%}
group.xmas_lights
{%- endif -%}
- platform: state
