Hi
Is there a possibility, to do an action with a condition like this:
- if the answer from Google Gemini is yes, then do the following action XY
- if the answer from Google Gemini is no, do nothing
Thanks & Best Regards
Stefan
Hi
Stefan
you must exploit the response of your prompt with response_variable which contains the response of your prompt
response_variable: response
action: system_log.write
metadata: {}
level: error
message: log the {{ response.response_text }}
enabled: true
Thanks @Jcarlier . Can you (or someone else) make this a bit more specific or tell me how exactly I have to do this? I am still relatively new in HA and accordingly I do not know everything from HA.
Best Regards,
Stefan
Your question is a bit general.
to analyze the response of a question to an AI is done via a prompt.
you can obviously analyze his response.
an example that I use:
at any movement in front of a camera, I ask gemini to analyze the image (snapshot) via a prompt.
I’ll give you the YouTube URL:
https://www.youtube.com/watch?v=SOjaOq25hgg&t=298s&ab_channel=MichaelLeen
