iFlo Hvac device
Anyone knows if there's something for this device?
It uses a ESP32-S2-SOLO chip. https://iflo.com/
Their refill bottles have a QRcode that is scanned on their app to "authorize" a bottle. Each bottle has about 6 shots and when they are done the bottle gets unauthorized.
I'd like to maybe reuse one of those bottle with white vinegar or some ther solution to dispense from HomeAssistant.
Interesting approach. I wonder how they handle the situation if someone is ordering refills from amazon, taking photo of the qr-code and returning the item...
Anyway, if you open the device, you likely find simple circuit allowing either flashing the Esp or substituting it with another.
But considering it's powered from few AA batteries, the device has to be mostly offline.
Please note that most of this info has been me fiddling around with the device and asking ClaudeAI questions about what I'm seeing. It could be totally incorrect, please don't risk devices based on my "research".
To answer your question it should work. From what I understand once you "activate" the bottle validity trough the app the device gets a variable set indicating that the bottle is valid and the amount of dispenses it has left. (There's some with 3 and others with 6). Once the dispense counter reaches 0 the bottle becomes invalid until a new one is scanned. Once the system has a valid bottle set you could switch it to dispense anything you want but just for the number of dispenses valid for that bottle.
Getting bottles from Amazon just to get the code, although unethical, should allow you to keep activating the device for whatever amount of dispenses and I guess it's something that happens cause I've read about people getting "new" bottles that won't validate.
Another thread was collecting used codes to try and find an algorithm to generate codes but I don't think that has gone anywhere, nor is something I'm too interested in doing.
Here's a couple pics of the board. Not the best pics but should give an idea.
Hardware:
  • MCU: ESP32-S2-SOLO, 4MB
  • Power: 4x AA batteries (two pairs of series cells in parallel) monitored via ADC on IO27
GPIO Map (take this with a grain of salt, I tried mapping this to the best of my limited ability):
GPIO Function Notes
IO18 LED 3 Output
IO19 LED 2 Output
IO21 LED 1 Output
IO25 Daughterboard KEY button Input, not sure what the button does, maybe reset
IO27 Battery ADC 2S2P pack, ~3V nominal
IO32 Valve OPEN INB assuming open but could be close
IO33 Valve OPEN INA assuming open but could be closed
IO34 Front button Wake / dispense
IO35 Float switch Daughterboard PIP, Input
GPIO6 (SD0) Bottle switch can wake device when opened or closed
GPIO9 (SD2) Valve CLOSE INA assuming close but could be wrong
GPIO10 (SD3) Valve CLOSE INB assuming close but could be wrong
I'm still missing one LED. I was pretty sure I found it but turns out is an NC pad on the esp32
And I believe the actuator uses one set of pins to open and another set to close. I'm pretty sure the valve will remain in position if not fully open or closed and power removed.
I don't know exactly how the actuator works but there's a separate area with a circuit were the actuator leads go to. I'm assuming kind of a relay to drive the actuator.
A summary on how I think it works:
  • Device runs on a schedule synced from https://backend.iflo.com (seen the dns requests in my router)
  • documentation says it auto adjust dispense days based on weather but in my experience it dispenses every 14 days.
  • Last dose: valve opens, device enters deep sleep, valve stays open (latching solenoid holds). I'm assuming this because when I removed the depleted bottle I could hear the valve actuating, so at least the bottle detection switch wakes the device.
  • Bottle validation requires a server call — the device sends the bottle ID and gets back max-doses and dispense timings.
There's a Local Web UI (device must be on your network)
Hit http:///settings.html while connected.
Available endpoints that I could find)
GET /dev_info — JSON status (battery, signal, doses, bottle status, mode)
POST /dev_actions — reboot, factory reset, manual dispense, toggle NAM mode, toggle demo mode, set device type, enable float
GET /ota.html — local OTA firmware upload (max 1572KB, minimum accepted version 2.20.5)
GET /offline_settings / GET /offline_data — offline mode data handlers
GET /scan_wifi — WiFi scan
GET /fwver — firmware version
You should investigate the other end of those two white connectors (OUTA/B/A1/B1) . To open and close single solenoid valve four gpio pins is not needed.
Yeah. There's also a barrel connector which I'm assuming is for using an ac adapter and those INA and INB could be the ones handling that but not 100% sure.
Only you know what is connected and where...
One pair OUTA/B should be enough to drive one latching solenoid. Those 8-pin ICs are likely taking care of the polarity swap according to INA/B signal.
@jaas666 any updates on your progress with this? I have an iFlo and love the idea of using my own solution, instead of buying the overpriced bottles.
Has anyone looked into intercepting the network call from the device? That seems like a viable option if we can find out the payload of the response.
Guess who woke up at 3am sweating like a pig with a clogged drain? That seals the deal for me.
I’m retaking this project and fully converting my unit to ESPHome to dispense vinegar instead of this scam.
Depending on drain pan, vinegar might cause corrosion issues in long term. One bottle of industrial biocide like ADBAC would last for the rest of your life.
Main board looks dead simple, you never posted what is really connected to those white connectors.
I built something similar to the iFLO before I knew the iFLO existed. I bought a cheap peristatic pump from amazon to dispense liquid. I use a TP-link wifi on/off switch to control the pump, but I guess any old switch would do. I built a wooden stand and attached a 5 quart (I’m lazy, don’t want ot refill often as it’s in the attic) tank to hold the liquid. I have a home assistant automation that runs in the middle of the night to turn on the switch for a brief time to dispense, then turn it off. Probably cost $50-$60 per unit in materials all in.
I have three HVAC systems. I built two dispenser systems to start because I wanted to see if enzyme cleaner or vinegar was better. One tank I filled with enzyme cleaner and the other tank I filled with vinegar. I have been running both for about three months and so far no issues. When the tanks get low I’m going to check out what the drain pipes look like and then make plan for all three HVAC systems based on the results.
Photo of the dispensers attached.
