iFrame Dashboard (Not have to reload them from switching dashboard)
Hello Home Assistant community,
I use Home Assistant on my Server as a docker container as such I love to use the iFrame Dasboard feature to display also the webUI of other docker containers I use like portainer, Plex and others (It’s the perfect Server Homepage).
The problem is that Home Assistant do not keep in memory the website everytime you pass from one dashboard to another and sometimes can be annoying for working between dfferent containers as it needs to reload the page everytime and loose the position you were in the page before.
Is it possible to not have to reload the pages everytime I switch to another iFrame Dashboard? Is there a setting to set this up, maybe in the YAML or currently it is not possible and could be a feature request?
Thank you
