Hi All:
Very new to home assistant. I have ultra-loqs (wifi, not z-wave). They don’t appear to natively integrate. I am trying to use IFTT as a middleman. Essentially, I want to:
If
Door is uunlocked
Then
Send webhook
Within home assistant then I want an automation where:
Trigger:
receive webhook
Action: Turn on downstairs light
I have duckdns setup (I think correctly as I can access home assistant via cell)
I setup iftt in home assistant and got
https://.duckdns.org:8123/api/webhook/
I was able to create the applet in IFTT. It appears to work (in log says applet run)
However, my automation does not run in home assistant.
I am unsure what I am doing wrong, and would love some help.
I am unsure if my webhook is set up correctly in IFTT
I have the URL
Method: post
content type: application/json
I don’t have anything in additional headers or body. Do I need something here? Also, I don’t really understand how they work.
Would love some help with setting up the webhook, or if anyone has an easier way to integrate my ultraloq into home assistant.
Thanks!
