IFTTT and Meross smart plugs
Hi all,
I’ve searched a lot of info in the community and I was able to configure meross smart plugs with IFTTT and Home Assistant, using template switch, input boolean and webhook.
Now, I’m asking if there is a way to call back Home Assistant if the turn on/off is activate physically on the smart plug.
Or “simpler” if there is a device refresh/polling to update state on the home assistant.
Thanks in advance.
Marco
Hi!
Why don’t use the custom component for Meross devices?
I’ll try the component in the next days.
Marco
Everyone know why Meross integration with IFTT does not work anymore?
When try to select trigger device it keep loading as below :
It seem that Meross does not keep this integration as many chinese makers …
