IFTTT configuration without API Key
After IFTTT changed their web site I cannot seem to find the API key described on https://home-assistant.io/components/ifttt/
In the documentation the configuration is:
ifttt:
  key: xxxxx-x-xxxxxxxxxxxxx
What you get from the maker channel now is the following:
Account Info:
Connected as USERNAME
URL https://maker.ifttt.com/use/STRING
Status active
How do I connect to IFTTT after the change?
Try to use the value STRING of your posted link
Hehe, I had tried that, but had made a mistake. So yes, that solves it, will see if I can update the documentation!
https://github.com/home-assistant/home-assistant.github.io/pull/1434
