so, i want to move away from the API password, so i enabled the new ifttt integration
i also added the automation as described here : https://www.home-assistant.io/components/ifttt/
see below
so this was my old ifttt webhook that is working
url : https://url:8123/api/services/google_keep/add_to_list?api_password=
body : { “title”:“Shop”, “items”:“testtest” }
so how do i tho this now?
i have an new url like :
# https://url/api/webhook/longlonglonglongtexthere
, this one i have putted in as new url in ifttt applet
but what do i need to setup in the body ?
this is not working :
`{ "action": "call_service", "service": "google_keep.add_to_list", "title":"Shop", "items":"testtest"}`
automation:
platform: event
event_type: ifttt_webhook_received
event_data:
action: call_service
service_template: '{{ trigger.event.data.service }}'
data_template:
entity_id: '{{ trigger.event.data.entity_id }}'
ok, a step further now
i am using text ingredients in IFTTT, seems that ingredient is not passing correctly
so body :
{ "action": "call_service", "service": "google_keep.add_to_list", "title":"shoplist", "items":"{{TextField}}" }
automation is changed to :
data_template:
title: '{{ trigger.event.data.title }}'
items: '{{ trigger.event.data.items }}'
this is resulting i a strange line added to my shoplist like:
<built-in method items of dict object at 0x7fa82dd582d0>
hmm, nothing todo with the text ingredient field
if i change the body to :
{ "action": "call_service", "service": "google_keep.add_to_list", "title":"shoplist", "items":"testitem" }
the same strange line is added : <built-in method items of dict object at 0x7fa82dd582d0
i know the command works, because i i change my automation to :
data_template:
items: "testitem"
it works
ok, solved it, seems the word “items” i cant use that …
so i changed it from “items” to another word “shop” for instance
{ "action": "call_service", "service": "google_keep.add_to_list", "title":"Colruyt", "shop":" {{TextField}}" }
and in automation :
data_template:
items: '{{ trigger.event.data.shop }}'
strange, but now it works
