I try to run config, containing
esp32:
board: esp32doit-devkit-v1
framework:
type: esp-idf
sdkconfig_options:
CONFIG_FREERTOS_UNICORE: y
advanced:
ignore_efuse_mac_crc: true
ignore_efuse_custom_mac: true
on ESP-WROOM-32D
After successful flashing device loops in reboot, infinitly printing:
[14:38:16.003]rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
[14:38:16.003]configsip: 0, SPIWP:0xee
[14:38:16.003]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[14:38:16.003]mode:DIO, clock div:2
[14:38:16.003]load:0x3fff0030,len:6268
[14:38:16.019]ho 0 tail 12 room 4
[14:38:16.019]load:0x40078000,len:15620
[14:38:16.025]load:0x40080400,len:4
[14:38:16.025]load:0x40080404,len:3648
[14:38:16.025]entry 0x40080608
[14:38:16.035]I (60) boot: ESP-IDF 5.4.2 2nd stage bootloader
[14:38:16.035]I (60) boot: compile time Oct 5 2025 02:44:08
[14:38:16.035]W (60) boot: Unicore bootloader
[14:38:16.045]I (62) boot: chip revision: v1.0
[14:38:16.045]I (65) boot.esp32: SPI Speed : 40MHz
[14:38:16.051]I (69) boot.esp32: SPI Mode : DIO
[14:38:16.051]I (72) boot.esp32: SPI Flash Size : 4MB
[14:38:16.051]I (76) boot: Enabling RNG early entropy source...
[14:38:16.051]I (80) boot: Partition Table:
[14:38:16.067]I (83) boot: ## Label Usage Type ST Offset Length
[14:38:16.075]I (89) boot: 0 otadata OTA data 01 00 00009000 00002000
[14:38:16.075]I (96) boot: 1 phy_init RF data 01 01 0000b000 00001000
[14:38:16.083]I (102) boot: 2 app0 OTA app 00 10 00010000 001c0000
[14:38:16.093]I (109) boot: 3 app1 OTA app 00 11 001d0000 001c0000
[14:38:16.099]I (115) boot: 4 nvs WiFi data 01 02 00390000 0006d000
[14:38:16.099]I (122) boot: End of partition table
[14:38:16.099]I (125) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=17ad8h ( 96984) map
[14:38:16.142]I (166) esp_image: segment 1: paddr=00027b00 vaddr=3ff80000 size=0001ch ( 28) load
[14:38:16.147]I (166) esp_image: segment 2: paddr=00027b24 vaddr=3ffb0000 size=03514h ( 13588) load
[14:38:16.147]I (175) esp_image: segment 3: paddr=0002b040 vaddr=40080000 size=04fd8h ( 20440) load
[14:38:16.164]I (185) esp_image: segment 4: paddr=00030020 vaddr=400d0020 size=88504h (558340) map
[14:38:16.352]I (376) esp_image: segment 5: paddr=000b852c vaddr=40084fd8 size=109a8h ( 68008) load
[14:38:16.386]I (413) boot: Loaded app from partition at offset 0x10000
[14:38:16.391]I (413) boot: Disabling RNG early entropy source...
[14:38:16.425][I][logger:165]: Log initialized
[14:38:16.428][C][safe_mode:084]: Unsuccessful boot attempts: 4
[14:38:16.435][D][esp32.preferences:143]: Writing 1 items: 0 cached, 1 written, 0 failed
[14:38:16.441][I][app:073]: Running through setup()
[14:38:16.441][C][component:163]: Setup preferences took 0ms
[14:38:16.441][C][component:163]: Setup power_supply took 1ms
[14:38:16.457][C][component:163]: Setup ledc.output took 0ms
[14:38:16.461][C][component:163]: Setup ledc.output took 0ms
[14:38:16.468][C][component:163]: Setup ledc.output took 0ms
[14:38:16.475][C][component:163]: Setup ledc.output took 0ms
[14:38:16.489][D][light:086]: 'yeelight-light-ceilc night light' Setting:
[14:38:16.491][D][light:092]: Color mode:
[14:38:16.491][D][light:137]: Transition length: 1.0s
[14:38:16.500][C][component:163]: Setup light took 11ms
[14:38:16.505][D][light:086]: 'yeelight-light-ceilc ceiling light' Setting:
[14:38:16.505][D][light:092]: Color mode: Cold/warm white
[14:38:16.521][D][light:137]: Transition length: 1.0s
[14:38:16.521][C][component:163]: Setup light took 10ms
[14:38:16.525][D][light:086]: 'yeelight-light-ceilc ambient light' Setting:
[14:38:16.525][D][light:092]: Color mode: RGB
[14:38:16.538][D][light:137]: Transition length: 1.0s
[14:38:16.538][C][component:163]: Setup light took 11ms
[14:38:16.580][D][esp-idf:000]: E (716) system_api: Base MAC address from BLK0 of EFUSE CRC error, efuse_crc = 0xb5; calc_crc = 0xdets Jun 8 2016 00:22:57
Does it mean ignore_efuse_mac_crc is not working?
