Ignore Lifx discovered device doesn't work
Hello Everyone,
I’m doing some cleanup in my HA.
I have a Lifx bulb that was linked with the Lifx Integration.
I remove the bulb/integration and wanted to started using this bulb through the HomeKit Integration (response time is slightly better with HomeKit).
The bulb works fine… but I get this Lifx discovered integration. I select Ignore… and it comes back after a few minutes later (1 hour or less).
I’ve ignored other integration in the past and it worked fine.
How can I ignore the Lifx discovery permanently?
Please open a new issue for this here:
ok done here https://github.com/home-assistant/core/issues/76815
This should be fixed in 2022.8.5.
Confirmed working with 2022.8.5. Thank you!
