I’m very new to HA so apologies if this is easy. I did try to find an existing question but couldn’t find one that deals with this particular logic.
I want to perform the following:
If <trigger x> occurs then
wait 20 seconds to see if <trigger y> occurs
if <trigger y> did occur then
do nothing
else
do stuff
I think it’s quite easy if “do nothing” and “do stuff” were the other way around - I could use a wait template and not continue on timeout. But how do I continue on timeout, but not continue if occurred?
You can do that with a condition which checks if a timer is running in an automation.
When you get the trigger 1 of the actions will be to start a timer, from the GUI you can pick a timer entity or create a helper in which you will set the duration.
Then the condition would be to check the state of the timer entity or helper if its idle
Something like:
description: "block for 10sec"
mode: single
triggers:
- trigger: state
entity_id:
- "your trigger"
to: "on"
conditions:
- condition: state
entity_id: timer.helper_timer
state: idle
actions:
- action: timer.start
metadata: {}
data: {}
- action: whatever you want todo
Just an example, best to create it in the GUI in automations.
