Hi
I’m trying to get HA to talk to my IHC installation.
HA is on the same network as IHC
Administrator connection to IHC from that network works fine through browser.
If I enter wrong username and password in configurations.yaml the log reports authentication error, which makes me believe connection is made correctly when entering correct info.
configuration.yaml setting:
IHC Controller
ihc:
url: ‘http://192.168.x.x’
username: username
password: password
auto_setup: true
info: true
The log reports:
Error during setup of component ihc
File “/usr/src/homeassistant/homeassistant/setup.py”, line 174, in _async_setup_component
component.setup, hass, processed_config # type: ignore
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/src/homeassistant/homeassistant/components/ihc/init.py”, line 211, in setup
if not ihc_setup(hass, config, controller_conf, index):
File “/usr/src/homeassistant/homeassistant/components/ihc/init.py”, line 230, in ihc_setup
hass, config, ihc_controller, controller_id
File “/usr/src/homeassistant/homeassistant/components/ihc/init.py”, line 296, in autosetup_ihc_products
discovery_info = get_discovery_info(component_setup, groups, controller_id)
File “/usr/src/homeassistant/homeassistant/components/ihc/init.py”, line 306, in get_discovery_info
groupname = group.attrib[“name”]
KeyError: ‘name’
Where to go fromhere? What are the requirements in IHC to make this work?
IHC Visual 2 - Hardware 6.1 - Firmware 2.7.220
