IKEA Bilresa Dual Button (Matter) – Light Control with Events & Sensors
This blueprint is designed to unlock the full potential of the IKEA Bilresa Smart Dual Button when used via Matter/Thread to control your Smart Lights.
(Note: This blueprint is optimized for Lights only. It does not support Media Player/Volume control in this version.)
The Matter implementation of this device can sometimes be tricky regarding “Hold” actions. This blueprint uses a custom Hybrid Engine to solve this.
:rocket: Key Features
  • :high_voltage: Hybrid Engine:
    • Clicks use Events for instant reaction (Toggle, Scenes).
    • Dimming uses Sensors in a smart loop. This ensures butter-smooth dimming that stops exactly when you release the button.
  • :atom_symbol: Atomic Control:
    • Dual Button Logic: Configure the Single Dot (Button 1) and Double Dot (Button 2) independently.
    • Gestures: Assign specific actions for Short Press, Double Press, and Hold (e.g., Dimming, Color Change, or Scenes).
:clipboard: Requirements (Crucial!)
To make the Hybrid Engine work, you must enable two types of entities for the remote in Home Assistant:
  1. ENABLE Events: Look for the event entities for Button 1 and Button 2.
  2. ENABLE Sensors: Look for the sensors often named “Switch Status” or “Position” (values 0 or 1) for Button 1 and Button 2.
:light_bulb: Setup Tip regarding Lights
If you want to control multiple lights at once (e.g., a room), please create a Helper Group (Light Group) in Home Assistant and select that group in the blueprint.
Targeting multiple individual entities directly via the blueprint may cause synchronization issues (“Popcorn effect”).
:inbox_tray: Import Blueprint
Open your Home Assistant instance and show the blueprint import dialog with a specific blueprint URL pre-filled.
Or import manually using this URL:
https://gist.github.com/stone13/03c873c4a7430bc60f2dd1d42be30590
:gear: Configuration Guide
  • Event Button 1 / Sensor Button 1: Map these to the “Single Dot” button entities.
  • Event Button 2 / Sensor Button 2: Map these to the “Double Dot” button entities.
  • Actions: Choose “Hybrid Dimming” for the Hold-Action to enable the smooth dimming loop.
Version History
  • V1.0: Initial Release (Hybrid Edition). Dedicated Light Control with Event/Sensor fusion.
🇩🇪 Klicke hier für die Deutsche Beschreibung
Dieser Blueprint ist der ultimative Controller für den IKEA Bilresa Smart Dual Button (den kleinen ovalen Schalter mit 2 Tasten) über Matter/Thread.
(Hinweis: Dieser Blueprint ist rein auf Lichtsteuerung optimiert.)
Die Matter-Integration dieses Schalters hat oft Probleme, das “Loslassen” der Taste beim Dimmen sauber zu erkennen. Dieser Blueprint löst das mit einer Hybrid Engine.
:rocket: Die Highlights
    • Klicks nutzen Events für sofortige Reaktion (An/Aus, Szenen).
    • Dimmen nutzt Sensoren. Der Blueprint prüft in einer Schleife, ob die Taste noch gedrückt ist (“1”). Das garantiert weiches Dimmen ohne Ruckeln.
    • Dual Button: Konfiguriere die Taste mit einem Punkt und die mit zwei Punkten komplett getrennt.
    • Gesten: Belege Kurz, Doppelklick und Halten individuell (z.B. Dimmen, Warmweiß/Kaltweiß, Szenen).
:clipboard: Voraussetzungen (Wichtig!)
Damit die Hybrid-Technik funktioniert, musst du in Home Assistant zwei Arten von Entitäten aktivieren:
  1. Events: Die Event-Entitäten für Taste 1 und Taste 2.
  2. Sensoren: Die Sensoren (oft “Schalterstellung” oder “Switch Status”), die anzeigen, ob die Taste gedrückt ist (0 oder 1).
:light_bulb: Wichtiger Tipp für Lampen
Wenn du mehrere Lampen gleichzeitig steuern willst, erstelle bitte unbedingt eine Helfer-Gruppe (Light Group) in Home Assistant.
Einzelne Lampen direkt anzusteuern kann zu Synchronisationsfehlern führen.
If you used AI/LLMs to generate this blueprint then you must state this at the beginning of the post.
Thank you for the Blueprint. Now dimming really works for me.
Question though, where does a doubleclick gets configured? Or is this still hardcoded in the YAML?
Would be great if that configuration could be added as well.
Or... if this Blueprint here and this one (IKEA BILRESA E2489 Matter Smart Button - Blueprint) could be merged :slight_smile:
