IKEA BILRESA Matter Button πŸ‘ˆ [Blueprint] for Ikea *Matter over Thread* Button (Actions, Scripts, and Entities)!
@censay could this be an example on long_press change:
# IKEA BILRESA E2489 Dual Button
# Blueprint Template v1.0.4
# Internal Versioning:
#   schema_version: 1.0.4
#   last_updated: 2026-01-18
# Changelog:
#   v1.0.4: Added Long Press to triggend during long press when button are still held down (long_press)
#   v1.0.3: Added not_from/not_to filters to prevent re-triggering on HA/Matter restarts (https://community.home-assistant.io/t/ikea-bilresa-matter-button-blueprint-for-ikea-matter-over-thread-button-actions-scripts-and-entities/962344/12)
#   v1.0.2: Initial release
# Power-User Notes:
#   - This device exposes two event entities, one per physical button.
#   - You must select the correct event entity for Button 1 and Button 2.
#   - Each press updates the entity state (timestamp) and sets attributes.event_type.
blueprint:
  name: IKEA BILRESA E2489 Dual Button (Matter)
  author: censay,bjornh
  description: >
    Full-featured automation for the IKEA BILRESA E2489 Matter dual-button
    remote. Supports single press, double press, and long press (on release)
    for both buttons. Uses event entities exposed by Home Assistant for
    Matter devices. Single-press actions are prioritized for reliability.
  domain: automation
  source_url: https://github.com/censay/haos-blueprints
  homeassistant:
    min_version: 2025.12.1
  input:
    target_device:
      name: BILRESA Button Device
      description: >
        Select the IKEA BILRESA E2489 matter device.
      selector:
        device:
          filter:
            - manufacturer: IKEA of Sweden
    button1_event:
      name: Button 1 – Event Entity
      description: >
        Select the event entity for Button 1 (for example:
        event.bilresa_dual_button_button_1_2).
      selector:
        entity:
          domain: event
    button2_event:
      name: Button 2 – Event Entity
      description: >
        Select the event entity for Button 2 (for example:
        event.bilresa_dual_button_button_2_2).
      selector:
        entity:
          domain: event
    # BUTTON 1 ACTIONS
    button1_single:
      name: Button 1 – Single Press
      description: Action for Button 1 single press (multi_press_1).
      default: []
      selector:
        action: {}
    button1_double:
      name: Button 1 – Double Press
      description: Action for Button 1 double press (multi_press_2).
      default: []
      selector:
        action: {}
    button1_long:
      name: Button 1 – Long Press (on release)
      description: Action for Button 1 long press completion (long_release).
      default: []
      selector:
        action: {}
    button1_long_press:
      name: Button 1 – Long Press (held down)
      description: Action for Button 1 long press during button are down (long_press).
      default: []
      selector:
        action: {}
    # BUTTON 2 ACTIONS
    button2_single:
      name: Button 2 – Single Press
      description: Action for Button 2 single press (multi_press_1).
      default: []
      selector:
        action: {}
    button2_double:
      name: Button 2 – Double Press
      description: Action for Button 2 double press (multi_press_2).
      default: []
      selector:
        action: {}
    button2_long:
      name: Button 2 – Long Press (on release)
      description: Action for Button 2 long press completion (long_release).
      default: []
      selector:
        action: {}
    button2_long_press:
      name: Button 2 – Long Press (held down)
      description: Action for Button 2 long press during button are down (long_press).
      default: []
      selector:
        action: {}
# AUTOMATION LOGIC
variables:
  button1_entity: !input button1_event
  button2_entity: !input button2_event
  - platform: state
    entity_id: !input button1_event
    not_from: 'unavailable'
    not_to: 'unavailable'
  - platform: state
    entity_id: !input button2_event
  # Added not_from/not_to filters to prevent re-triggering on HA/Matter restarts; event entities use timestamp states
condition: []
  - variables:
      press_type: "{{ trigger.to_state.attributes.event_type }}"
      trigger_id: "{{ trigger.id }}"
  - choose:
      # BUTTON 1
      - conditions:
          - condition: template
            value_template: >
              {{ trigger_id == 'button1' and press_type == 'multi_press_1' }}
        sequence: !input button1_single
      - conditions:
            value_template: >
              {{ trigger_id == 'button1' and press_type == 'multi_press_2' }}
        sequence: !input button1_double
      - conditions:
            value_template: >
              {{ trigger_id == 'button1' and press_type == 'long_release' }}
        sequence: !input button1_long
      - conditions:
            value_template: >
              {{ trigger_id == 'button1' and press_type == 'long_press' }}
        sequence: !input button1_long_press
      # BUTTON 2
      - conditions:
            value_template: >
              {{ trigger_id == 'button2' and press_type == 'multi_press_1' }}
        sequence: !input button2_single
      - conditions:
            value_template: >
              {{ trigger_id == 'button2' and press_type == 'multi_press_2' }}
        sequence: !input button2_double
      - conditions:
            value_template: >
              {{ trigger_id == 'button2' and press_type == 'long_release' }}
        sequence: !input button2_long
      - conditions:
            value_template: >
              {{ trigger_id == 'button2' and press_type == 'long_press' }}
        sequence: !input button2_long_press
mode: restart
