According to your screenshot you’re using another blueprint, maybe this one?
Hi, I love this Blueprint. Thanks for the efforts of everyone involved.
I just wanted to highlight an issue I had and the solution...
Problem:
I've mapped the long-press event to an automation which turns on my livingroom lights and tv. This automation involve a 5s time delay between the TV's wake-on-lan and selecting it's input source.
The automation worked fine when triggered from the UI, but when triggered from a button long-press, the trace kept showing that it was cancelled.
It turns out the long-release event along mode 'restart' was the cause of the problem. The long-release event cancels any previously running automations.
Solution
Set mode to 'parallel'
(Once I figure out how to work with blueprints, I'll reply with the yaml to make the mode setting configurable)
This blueprint works perfect. Hoping it solves my ghost click issue with several of my Bilresa buttons. I was also able to condense several automations to one now. Thanks so much for creating this!
Great work, thank you!
I have been using this for about 2 weeks. Ive noticed that when i have mapped to “toggle” function lights on/off. It stops turning off lights after about a week. It can however turn lights on fine. Restarting HA fixes it
Is this a HA issue or blueprint issue?
Hi
I have no idea how to add Brightness Up for a light.
The light is connected via Zigbee2MQTT.
Single Click on 1 is PowerON
Double Click on 1 sets a state
Single Click on 2 is Power Off
But that is all I can do for now.
Anyone that can share a way of doing Brightness Up and Down when holding the Buttons?
never mind. I have upgraded HA OS and the issue hasn’t reoccurred for 2 months.
Thanks! I wish I had seen this before I made my buttons.
