Issue
My IKEA Tradfri bulbs are no longer showing color_temp in HA (but can still control)
HA: 2025.3.1
Z2MQTT: 2.1.3
IKEA Bulb Firmware: 3.0.23
I can see the color temp within Zigbee2mqtt
But in Home Assistant, its all reported as null
I can still control the color temperature via HA light card, but, once you navigate away and back again, there is no value on the slider
I’ve restarted both HA and Z2M. Logs show payload of color temp being sent within zigbee2mqtt (makes sense as I can control it). Not sure of what other logs and where I can be looking to further troubleshoot this issue. Thank you
after some more searching, found this post at github
opened 10:23AM - 06 Mar 25 UTC
closed 07:25PM - 09 Mar 25 UTC
problem
### What happened?
https://www.zigbee2mqtt.io/devices/404006_404008_404004.html… stopped showing value of `color_temp` sensor attribute, (it's always `null`) after update HA to 2025.3.
min_color_temp_kelvin: 2702
max_color_temp_kelvin: 6535
min_mireds: 153
max_mireds: 370
effect_list: blink, breathe, okay, channel_change, finish_effect, stop_effect
supported_color_modes: color_temp
effect: null
color_mode: color_temp
brightness: 255
color_temp_kelvin: null
color_temp: null
hs_color: null
rgb_color: null
xy_color: null
friendly_name: Bulb
supported_features: 44
However MQTT message contains proper `color_temp` value. Color temperature can be set precisely via HA color temp control, but not via `color_temp` sensor attribute as I did within automations.
Z2M 2.1.3
HA 2025.3.0
light/config
availability:
- topic: zigbee2mqtt/bridge/state
value_template: '{{ value_json.state }}'
brightness: true
brightness_scale: 254
command_topic: zigbee2mqtt/bulb/set
device:
hw_version: 1
identifiers:
- zigbee2mqtt_0x00158d0002fddfdc
manufacturer: Müller Licht
model: Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white
model_id: 404006/404008/404004
sw_version: '2.0'
via_device: zigbee2mqtt_bridge_0x00124b0021b7800c
effect: true
effect_list:
- blink
- breathe
- okay
- channel_change
- finish_effect
- stop_effect
max_mireds: 370
min_mireds: 153
object_id: bulb
origin:
sw_version: 2.1.3
support_url: https://www.zigbee2mqtt.io
schema: json
state_topic: zigbee2mqtt/bulb
- color_temp
unique_id: 0x00158d0002fddfdc_light_zigbee2mqtt
### What did you expect to happen?
Sensor `color_temp` attribute shall have current value of color temperature as for other bulb models.
### How to reproduce it (minimal and precise)
_No response_
### Zigbee2MQTT version
2.1.3
### Adapter firmware version
20240710
### Adapter
ZBDongle-P
### Setup
docker
### Debug log
_No response_
with the last reply in the thread being someone that has raised the issue with home-assistant/core (here )
Will try to revert to 2025.2.5 and report back.
Edit: didn’t end up reverting as I have yet to do a rollback since starting my HA journey and wasn’t sure how comprehensive it needed to be etc. however seems might be getting patched in a timely manner based on this post
Edit 2: solved with update
