As far as i know the secondary button is only active in matter mode.
So i had to switch back from zigbee, unfortunatly.
I also have this problem! What is this trigger even doing?
I can't get it to adjusting anything, can only toggle on and off the light.
Same...scroll does not work for me. Using ZHA.
Sadly both you and McInnes one do not seem to work with scrolling. Yours does not do anything one double click either...I need to go back to the McInnes one and see if double click works on that blueprint...EDIT- checked and that doesn't do double click or scroll either.
It's annoying cos if I wanted basic I'd have stuck with Alexa which sees it as 3 buttons -- up, down and click (called left, oddly). Interestingly it's a LOT faster over Alexa/Matter. There's a slight lag with this and my 2-button BILRESA, which Alexa does not have. Alexa is almost instantaneous...wondering if there's some lag with the Zigbee compatibility?
I am seeing button and MoveTo events in the ZHA Activity log, so it was definitely working.
That said the scroll doesn't work with shared Matter either via Alexa. So I am wondering if this is a duff one or whether the scroll only works with the hub?
