IKEA GU10 RGB led with deCONZ, issue when choosing white and white temperatures
Hi all
I’m trying to work with some Ikea GU10 RGB lamps.
I have created a group in HA with 3 lamps.
When I turn them on with a call service node, I would like to have always a cold white.
And I’m doing it with
    "rgb_color": [
        255,
        218,
        146
    "brightness_pct": 85
I’m using Alexa to manage this light, the Alexa Smart Home node passes a HUE value for all colors and a kelvin value when I ask for a white.
What I’m not able to do is to go back to a white from a color or to go back to a cold white after I asked for a warm white.
Also, after turning on in white color, as above, if I turn just brightness to another %, then when I ask for full brightness, I don’t get same white (almost cold), but a warm one…
This is what I’m doing when a white is requested
msg.payload =
    "kelvin": msg.colortemp
return msg;
and this is what I’m doing when I request a color
msg.payload =
    "rgb_color": [
        msg.payload[0],
        msg.payload[1],
        msg.payload[2]
return msg;
getting the RGB value from the color-convert node.
I tried to use the rgb_color values with kelvin values in the same data, but I get this error
Error Message: two or more values in the same group of exclusion 'Color descriptors' @ data[<Color descriptors>]"
What should be the correct way to do it?
