IKEA Remotes - Control anything
You’re doing it wrong you are binding the state of the lamp - > rodret.
But you have to do it the other way around.
State of the rodret - > lamp.
I hope this is clear.
Fix for flickering dimming
If you experience visible flickering between the dimming steps while holding on of the buttons, there is a fix.
@damru I kindly ask you to consider integrating this in your blueprint.
Fix
Use the transition functionality within the light_on-change brightness.
Simply set the transition time to 0.2 and the brightness percentage to 3 and remove the delay block.
This results in a fast and smooth dimming.
Would it be possible to paste the script here? Thanks
Hey
Thanks for the suggestions :bulb:
I removed the transition some times back but I’ll re-add it with the same value as the delay, this should smoothen the transition for lights that support it.
I’m considering removing the delay at once, but I have to run some tests as for the moment:
  • it loops too fast so the light “goes back to random %” instead of going to 1%
  • sometimes it even becomes an endless loop as it’s never triggering the end-loop condition
  • I dont find it good practice to spam actions to HA and the network
  • if HA is not blocking the script for the “transition” time (specialy for lights that dont support it), this would be a blocker
I’m reworking this and will post an update once I’m done (at least with the transition).
Now, if you have more questions/remarks, please use the related topic instead of this one :pray:
Thanks all for such a prompt responses and help!
First: yes, definitely, I used a wrong blueprint. I installed this one, while the other one (IKEA RODRET Dimmer + SOMRIG Remotes - ZHA/Z2M - Control Light) would fit my needs better.
I was just confused with names and didn’t notice that the last word is different :slight_smile:
Anyways, for my purposes direct binding remote to the group of lights worked better - basically offering the same experience as when it was just a connection w/o HA.
Next I’m going to purchase few more ikea remotes and use the “control light” blueprint to control other, non-ikea lights around the house.
This method worked for me when nothing else did. Pairing near another Ikea router was the key, I think. Thank you!
I have z2m + mqtt running and one somrig and 2 rodrets.
With z2m v2.0 the blueprint says no device found
Would be great to get some advice
edit:
I edited the blueprint and removed the filter and could manually select my rodret.
#         - integration: mqtt
#           manufacturer: IKEA
#           model: RODRET wireless dimmer/power switch (E2201)
Nevertheless the filter values are correct
hi, can you explain what you did?
regards
I access the configuration/blueprint path and edited the yaml with a text editor:
Perfect.This works.
Tank you!
@damru With z2m in V2 the double press event is also broken. If I click once it is handled as a double click event. Both buttons affected.
Thanks for pointing this out.
I did the change in the blueprint, this should be fixed now.
Hey,
I tried with my Rodret + Z2M, and could not reproduce your issue.
Did you try lowering the Double press delay ?
I will try again
Thanks a lot!
Just yesterday I had the problem, that the Ikea Rodret and the Ledvance mini switches I had just installed, were not accessible by the blueprints I had installed for them. In your blueprint, I was not able to select a device.
Since I am quite new to Z2M, and also new to these switches and to blueprints, I was not sure if this was a configuration problem, and in which part of home assistant.
Some minutes ago, I saw your posting, that you “did the change in the blueprint”, re-imported it, and now it is possible to select a device!
Thank you!
Hopefully the other blueprint for the Ledvance will also be updated to work with Zigbee2MQTT 2.0., I will see how to contact the author.
Single press is still recognized as a double press.
This seems to be a general problem:
The delay is on 300ms (also tested with 100ms) now.
this is that I get in the logs for a single press:
in zigbee2mqtt itself:
info 2025-01-06 09:53:48z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Rodret1', payload '{"action":"on","battery":84,"identify":null,"linkquality":212,"update":{"installed_version":16777303,"latest_version":16777303,"state":"idle"},"update_available":false}'
info 2025-01-06 09:53:48z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Rodret1', payload '{"action":"","battery":84,"identify":null,"linkquality":212,"update":{"installed_version":16777303,"latest_version":16777303,"state":"idle"},"update_available":false}'
info 2025-01-06 09:53:48z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Rodret1/action', payload 'on'
info 2025-01-06 09:53:58z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Rodret1', payload '{"action":"off","battery":84,"identify":null,"linkquality":212,"update":{"installed_version":16777303,"latest_version":16777303,"state":"idle"},"update_available":false}'
info 2025-01-06 09:53:58z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Rodret1', payload '{"action":"","battery":84,"identify":null,"linkquality":212,"update":{"installed_version":16777303,"latest_version":16777303,"state":"idle"},"update_available":false}'
info 2025-01-06 09:53:58z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Rodret1/action', payload 'off'
in Home Assistant → Addons → z2m → log
[2025-01-06 09:53:47] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Rodret1', payload '{"action":"on","battery":84,"identify":null,"linkquality":212,"update":{"installed_version":16777303,"latest_version":16777303,"state":"idle"},"update_available":false}'
[2025-01-06 09:53:47] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Rodret1', payload '{"action":"","battery":84,"identify":null,"linkquality":212,"update":{"installed_version":16777303,"latest_version":16777303,"state":"idle"},"update_available":false}'
[2025-01-06 09:53:47] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Rodret1/action', payload 'on'
[2025-01-06 09:53:56] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Rodret1', payload '{"action":"off","battery":84,"identify":null,"linkquality":212,"update":{"installed_version":16777303,"latest_version":16777303,"state":"idle"},"update_available":false}'
[2025-01-06 09:53:56] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Rodret1', payload '{"action":"","battery":84,"identify":null,"linkquality":212,"update":{"installed_version":16777303,"latest_version":16777303,"state":"idle"},"update_available":false}'
[2025-01-06 09:53:56] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Rodret1/action', payload 'off'
@damru looks like that the on action appears 6 times instead of just a single hit.
on the other side:
in the logbook the actions do not appear 6 times. They correctly reflected my button presses.
Can you check if you have some legacy option in your configuration.yaml ?
The behaviour on my end is correct.
I also already migrated the blueprint to the new device trigger specification (instead of using action button) a while back.
The only thing different from you that I can see is that I dont have the Action available anymore since migrating to Z2M v2.
No “legacy” options in my configuration (also checked the yaml file)
After a HA restart, the action button is gone:
And it seems to work now.
Disabling the option breaks the Styrbar E2002 :disappointed_relieved:
I setup the automation, all working as expected, but
i get an error in HA logs
Logger: homeassistant.components.automation.rodret_study
Source: components/mqtt/device_trigger.py:379
integration: Automation (documentation, issues)
First occurred: 12:15:03 PM (26 occurrences)
Last logged: 12:17:41 PM
Error setting up trigger Rodret Study
Traceback (most recent call last): File “/usr/src/homeassistant/homeassistant/components/device_automation/trigger.py”, line 65, in async_attach_trigger return await platform.async_attach_trigger(hass, config, action, trigger_info) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/src/homeassistant/homeassistant/components/mqtt/device_trigger.py”, line 379, in async_attach_trigger mqtt_data = hass.data[DATA_MQTT] ~~~~~~~~~^^^^^^^^^^^ KeyError: ‘mqtt’
I only use zha, not mqtt
So, i am wondering why i get this error
Is there anything i can do ?
thanks,
