(Z2M-ZHA) IKEA Somrig Multi-Control + Smart Battery Alerts
Works with: Z2M and ZHA
Requires addons to be installed MQTT + Z2M addon or ZHA
Key Features:
Smart Battery Monitoring:
- Automatically detects the battery sensor without manual configuration.
- Consistent device naming for battery notifications across Home Assistant and mobile devices.
- Adjustable battery percentage threshold for notifications.
- Customizable schedule for battery notifications based on selected days and times.
Flexible Button Controls:
- Full compatibility with both ZHA and Zigbee2MQTT integrations.
- Supports all button actions: single press, double press, and long press for one-dot and two-dot buttons.
- Configurable hold actions with adjustable delay and loop count for precise control.
Unified Notification System:
- Consistent device names displayed in both mobile and Home Assistant notifications.
- Automatic logging of battery status in the Home Assistant logbook when thresholds are met.
GitHub here.
Do you like this plan? Enjoy or button
The schedule has a device controller search box that only shows IKEA SOMRIG E2213 devices.
Press the one dot or two dots buttons
Double press the one dot or two dost buttons.
Press and hold the one dot or two dots buttons.
Helper
Quick Guide: Battery Alert Settings Overview
Select Notification Device
Choose the mobile device that will receive battery alerts.
Send Notifications to Home Assistant
Toggle on to also display battery alerts in the Home Assistant notification panel.
Battery Alert Threshold
Adjust the slider to set the battery percentage level at which you want to receive an alert (e.g., 20%).
Battery Alert Days
Select the specific days when battery alerts should be sent.
Battery Alert Time
Set the exact time when the battery alert should be triggered each selected day.
Hi, Iโm @Bearstorm
Check out my page www.bearstorm.com
Check GitHub page Bearstorm (Bearstorm) ยท GitHub
Support me
Apache License
Version 2.0, January 2004
http://www.apache.org/licenses/
