Ikea through matter devices are always unavailable
I have an ikea Dirijera hub, which was working pretty good with HomeKit. However, because of an IP change it became unavailable, so I deleted it and now I can’t add it again, so I decided to try the Matter integration.
The devices are indeed detected, but they always appear as “unavailable”. I don’t know what to do or how to debug this issue.
This is all what I can see in the logs:
2025-06-17 13:25:26.510 (MainThread) INFO [matter_server.server.device_controller] <Node:2> No new update found.
2025-06-17 13:25:26.515 (MainThread) INFO [matter_server.server.device_controller] <Node:1> No new update found.
2025-06-18 10:31:31.428 (MainThread) INFO [matter_server.server.device_controller] <Node:1> No new update found.
2025-06-18 10:31:31.438 (MainThread) INFO [matter_server.server.device_controller] <Node:2> No new update found.
2025-06-19 00:29:08.479 (MainThread) INFO [matter_server.server.device_controller] <Node:2> No new update found.
2025-06-19 00:29:08.487 (MainThread) INFO [matter_server.server.device_controller] <Node:1> No new update found.
2025-06-19 12:29:08.537 (MainThread) INFO [matter_server.server.device_controller] <Node:2> No new update found.
2025-06-19 12:29:08.543 (MainThread) INFO [matter_server.server.device_controller] <Node:1> No new update found.
2025-06-19 22:59:45.130 (MainThread) INFO [matter_server.server.device_controller] <Node:3> Node could not be discovered on the network, returning cached IP's
2025-06-19 22:59:45.164 (MainThread) INFO [matter_server.server.device_controller] <Node:3> Node could not be discovered on the network, returning cached IP's
2025-06-19 22:59:52.867 (MainThread) INFO [matter_server.server.device_controller] <Node:3> Node could not be discovered on the network, returning cached IP's
2025-06-19 23:00:08.151 (MainThread) INFO [matter_server.server.device_controller] <Node:3> Node could not be discovered on the network, returning cached IP's
2025-06-19 23:00:08.179 (MainThread) INFO [matter_server.server.device_controller] <Node:3> Node could not be discovered on the network, returning cached IP's
2025-06-20 00:29:08.322 (MainThread) INFO [matter_server.server.device_controller] <Node:2> No new update found.
2025-06-20 00:29:08.600 (MainThread) INFO [matter_server.server.device_controller] <Node:1> No new update found.
