IKEA Tradfri bulb previous state bleeding in to a new state
Hello here,
have a question, I started playing with HA automations, so far only the visual editor. One thing that I currently have some issues with is with a bulb’s previous state sort of bleeding into the new one when it is turn on again. I am using the Ikea Tradfri bulb with the full color spectrum connected via Zigbee2MQTT.
So what is the issue? For example when I want to set some fade in when the bulb is turned on, instead of starting in the state when the lightbulb is fully dimmed and then slowly increasing brightness it gets turned on to the previous brightness intensity and then got dimmed to lowest to do the fade in command.
Another example. I have set different color when the light is turned on in night and different color when it is turned on during day. When it is turned on during the day for the first time, it is visible for a second the lightbulb still has the color of the previous state before it switches to the current state.
Any idea how to fix this?
