IKEA Tradfri RGB Lamp
Hey guys,
has anyone successfully integrated the TRÅDFRI RGB lamp into HA? And if yes, can you change colors just like with every other RGB lamp from the UI?
I’d be very interested in your experiences as I’m currently thinking about buying the IKEA lamps.
Thank you!
Currently, Home Assistant recognizes the RGB bulb as a white ambience bulb. You can control white temperature and brightness, but no colour. Hopefully, they will add this soon.
There’s a PR in for it - https://github.com/home-assistant/home-assistant/pull/9717
But from reading the comments, they look to be trying to upstream it, which is the right way to do it, but may be a little longer (has to be implemented upstream in pytradfri and then in HASS)
